Old October 25th, 2003, 23:08
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
Tips on doing front axle ujoints?
Depending on time, I am planning to dig into them tomorrow..... any tips? potential problems??? Anything else I migt want to do while there??
Thanks
Old October 25th, 2003, 23:50
cbremer cbremer is offline
NAXJA Member #393
Location: So. Cal. Wine Country 3331'52.15"N, 11708'43.72"W
http://www.stu-offroad.com/misc/axle-1.htm
then
http://www.stu-offroad.com/misc/u-joint-1.htm
other stuff to do... change the front diff oil maybe? while you have the diff cover off and the shafts out, pull the carrier and replace the seals if they're leaking (if they're not, be very careful R&R-ing the axle shafts so as to not start a leak!)
if you need new brake pads, now's a good time to take care of them. lube the balljoints & tie rod ends.
not much else i can think of
D30 Front Axle Swaps (Non Disco vs. Disco) SnowyXJ Modified Tech Discussion 10 December 13th, 2003 09:27
Need to know quickly, Axle ??? Big Hank Modified Tech Discussion 4 December 7th, 2003 22:02
Will TJ front axle shafts fit into an XJ axle ? DaveB OEM Tech Discussion 3 December 2nd, 2003 14:40
front axle shims? BLUTO Modified Tech Discussion 6 April 27th, 2003 01:14
