KinesthesiaDrums
- Minot, ND
awight......i need some quick answers....i wanna have this thing drivable for monday....bare with me...never done this before...
installing rough country 4.5" lift on a 1990 2wd XJ....
last night i did the front install....everything but the track bar.....and i have two questions as to how the front turned out...
1- i put the tires back on it (original, small ones) and put it on the ground, decided to do track bar in the morning (now) cause i was out of light....when i dropped the jeep back on the ground the sway bar moves back into the coil springs.....i know thats not supposed to ride on the springs.....i tried to see if there was any way i could move the frame brackets any further forward, thats the only option for placing that i have...........
is this normal??? will it be fixed when i lift the rear?? help!?!?!?
2- the track bar....i know the majority says eff the bracket, get an adjustable....well....that will be next, but for right now i'ma hafta live with the bracket.....so anyways....i got 3 holes on the bracket....one mounts through the stock hole, one i'm supposed to use to drill out in the existing bracket behind it, and the other is where the track bar mounts in...
from my studies i concluded that the stock mount works as a kind of pivot point, and the hole i drill out holds the bracket in place for adjustment purposes of the track bar.....am i correct???
instructions say to mount with stock bolt....then drill hole and put in the supplied bolt and tighten....after tires are installed, put vehicle back on the ground and install track bar on the bracket....
now....if my "adjusting" assumption is correct....if i just randomly drill a hole and bolt it up, the track bar might not line up when i put the jeep back on the gound.....
soo....what should i do?? should i put the jeep on the ground, reinstall track bar and then drill the hole....or what?
and isn't the track bar for keeping the axle centered under the vehicle? so this all needs to be adjusted right.....??
i think yall get where im headed with the question.......
thanks in advance....
