96killgore
- San Antonio, TX
1996 xj classic, 4.0 inline 6, aw4 4x4, 255k original miles, left hand drive, no engine codes
So im stuck on what my problem could me, a few weeks ago i was at half a tank (fuel gauge is accurate along with i track miles with every fill up, and i use 93 octane fuel) but i started to hear a werid noise ive never heard before. Right between the driver side long skinny a/c vent, next to window, and kinda behind the instrument panel i heard a noise that sounded like a big vacuum trying to pull in air (it kinda sounded like a cold air intake attached to a turbo not thr whine but the sheer force of air veing forced into a large hose) but when this happened ny rpms went from idle (1300 rpms) all the way up to 2500 rmps and it started to accelerate like i was pushing on the gas. I was in a parking lot so i started to add brake to stop and it kept trying to accleratr forward never going over 2500 rpms but when i stopped the engine died. Then it started up and i drove it home next day same thing happens but i was able to slam on it and make it to a gas station where i filled it up. It died again but started right up and drove fine rest of day. Next day i took it to my buddys shop where we did fuel pressure test, fuel pressure we good along with the vacuum pressure. And from what i could tell throttle body looked good and throttle position sensor was fine. It ran a week fine and today i started it up, i park on level surface, the same noise came up but i was at more then 3/4 a tank. When i filled it up i revved it with throttle and it almost died again rpms droped o 650rpms for 5-7sec then returned to normal i then oppened hood and revved it at throttle body and had no problems and drove home 10miles away. So the only time it dies is when i hear that werid vaccum noise in the dash behind instrument panel and that is my only lead but i cant think of anything else that could help identify it please help (noise has been there when ac is running and not running)
