Hey guys, 96 4.0 XJ 80k miles, been doing some maintenance and decided to see what the check engine light was trying to tell me the other week.
Seems that its giving a P0138, which I believe is the sensor behind the Cat. What I am wondering is this an indication that the Cat is toast, or just that the sensor is failing?
How would I know if the Cat is not doing its thing?
I know that I have a cracked exhaust manifold, which may have gotten worse since its sounding a little like a diesel right now. This is all following an episode where I didnt notice my coolant was low and the engine got hot 230ish (with steam). After inspection, I see that the water pump is leaking. So I have to change the water pump & rip out the cooling components for an overhaul. I cant put my finger on the cause of this new diesel engine sound, could be the water pump making a racket, could be the crack in the exhaust got bigger when it got hot, I dunno yet (Im in AZ and its like 130+ degree's in my garage so Im being lazy & driving the wifes 97 XJ)..
Is there anything I can detect when the Cat goes bad?
Thanks.
Thanks.
