Old February 22nd, 2007, 15:21
cdhowell cdhowell is offline
Strange noise after gear Install
After going to 4:56 from 3:07 I have a strange, almost harmonic noise that comes in and out, about 70 mph. It seems to be in the rear but hard to tell. Quick Details, 97 Xj 8" Skyjacker lift, Tera SYE, 5-speed AX 15 I think Running 33's. Tru-trac front HP 30, open 8.25 rear. Noise is not steady ,but has a constant rythem. Hard to describe sounds. Maybe it was always there but did not see enough rpm in the drive train till the gear swap. Any Ideas?
Old February 22nd, 2007, 15:45
Re: Strange noise after gear Install
any one
Old February 22nd, 2007, 15:53
jpcherokeekid's Avatar
jpcherokeekid jpcherokeekid is offline
did you do the gears yourself? ive been told that if your gear patern and backlash are not set correctly (within a few thousandths) you will get noise and once it starts making noise it won't stop unless you change your gears out again.
Old February 22nd, 2007, 16:35
Stumpalump Stumpalump is offline
On a Time Out
Your drive-shaft is spinning a lot faster now and that could be your problem. Drop one at at time and see if the noise goes away.
Old February 23rd, 2007, 08:16
Yes I did the gears myself, and I am not new to gear installs. Pinion depth is set to spec on gear set and backlash at .007 calls for .005 - .009 A friend with a TJ is going thru the same thing at 70 mph. also running 4:56 and 33's . His is a D35 rear
Old February 23rd, 2007, 11:32
Absdad Absdad is offline
I'm having the same issue. Went with 4.56's and running 32's with my RPM's about 2900 at 70. I took the front ds out and it didn't make the sound go away. I also have a slight vibration at that speed. My rear ds is pretty dented up so it could be that.
I attribute it to the higher RPM's.
STRANGE Noise!! Quills OEM Tech Discussion 7 October 18th, 2006 18:36
Strange noise, only under power.. noisy gear set? twisted_ed OEM Tech Discussion 3 September 30th, 2006 17:36
strange noise homebrew OEM Tech Discussion 1 September 18th, 2006 20:57
Strange noise... Jump This SoCal Chapter 14 July 6th, 2005 00:20
Yet another strange noise... Motornoggin OEM Tech Discussion 2 March 26th, 2004 21:50
