Old May 28th, 2016, 15:41
FuryIII FuryIII is offline
CavFab 3 link....
What do you guys think of this kit?
http://cavfab.com/CavFab-Jeep-Cherok...Link_p_61.html
Old May 28th, 2016, 15:58
Bamaxj84's Avatar
Bamaxj84 Bamaxj84 is offline
CavFab 3 link....
I like it! Kinda what I been looking for.
Old May 28th, 2016, 19:02
rockclimber's Avatar
rockclimber rockclimber is offline
Associate
Re: CavFab 3 link....
I hope it uses more than just 3 bolts through the unibody on each side.
[cal]You're an idiot rockclimber.
[StinkyFab]RockClimber is a tool.
Old May 28th, 2016, 20:27
It has plates that mount to the side of the frame rail too.
Old May 29th, 2016, 05:07
RoyalXJ RoyalXJ is offline
Better than the B. Lee kit that everyone started buying.
Old May 29th, 2016, 07:44
need-a-bow's Avatar
need-a-bow need-a-bow is offline
Looks interesting. I like the fact that it has Johnny Joints vs heims
Old May 29th, 2016, 10:26
831_xj's Avatar
831_xj 831_xj is offline
Agreed this one doesn't seem like a bad buy for a kit
I know a little bit about nothing..
Daily MJ
yewwy crawler
Old May 31st, 2016, 07:46
POLAR_JEEP_04's Avatar
POLAR_JEEP_04 POLAR_JEEP_04 is offline
NAXJA Member #2130
not bad. I would still prefer a 3 piece cross member though.
Originally Posted by XJ&CHZ4ME View Post
Some see this as a silly online jeep club.........we are more than that, we are like family.
Buy from sponsors to support those who support our club!
http://sponsorship.naxja.org/
Join ... http://www.naxja.org/html/membership_faq.htm
Old June 2nd, 2016, 12:01
Jeepology Jeepology is offline
Just received this kit yesterday. First impressions only, but thoroughly impressed with the build quality. Build thread and some more photos here
http://www.cherokeeforum.com/f46/pro...cenary-224888/
Old June 2nd, 2016, 12:26
Ben824's Avatar
Ben824 Ben824 is offline
Seems like a nice kit for the money. I would like it more if they used clevite rubber bushings rather than polyurethane. My experience with polyurethane has been anything but good. Andy at IronMan 4x4 has quit using poly as well now and switched to rubber.
Old June 2nd, 2016, 20:45
Associate
CavFab 3 link....
The trick to poly bushings is getting the right durometer.
Most are using way too hard of bushings.
With the proper durometer you can get way more life out of a poly bushing than a clevite
Old June 2nd, 2016, 22:21
poomero poomero is offline
What's wrong with the b.lee kits? I wad thinking about one
Old June 2nd, 2016, 23:48
Not knocking B.Lee's kit but some observations between the two.
CavFab boxes in the control arm mounts, making them less apt to bend.
The shape of the cross member being angled in the front to better to slide over objects vs rectangular tube of B.Lee
I may be wrong but with cutouts for the drive shaft and exhaust on the CavFab crossmember the may mean a little more clearance.
There are side plates in the CavFab kit that bolt to the sides of the frame rail for added mounting strength.
Both run a Currie joint at the upper axle mount. As for the other control arm ends, I can't argue heims vs. Currie joints/poly bushings, I don't have experience with them.
B.lee will customize their arms with different ends if you like.
Both have a t-case skid in the works too.
CavFab regular price is a bit higher than B.lee's
Old June 3rd, 2016, 07:01
NAXJA Member #2130
I don't trust B Lee's cross member mounting to the unibody
Old June 3rd, 2016, 11:38
the_midwesterner the_midwesterner is offline
Completely, unrelated to his but I just realized you are the dude behind jeepologyoffroad instagram page.
Small world.
clayton 3 link and rear 4 link with under 6" of lift. josh9mile Modified Tech Discussion 11 August 17th, 2014 17:21
Synergy Suspension 4 link Or Rock Krawler 3 link whats better? Nick_n_ii Modified Tech Discussion 79 February 7th, 2011 10:56
drag link / sway bar link mount interference sarvermr Modified Tech Discussion 21 March 14th, 2007 07:19
Four link rear/URF three link front shakedown pics Roxtar Advanced Fabrication and Engineering 53 November 1st, 2005 15:41
3 link 4 link Potato potaaahto semantics? TOZOVR Modified Tech Discussion 38 January 7th, 2004 23:51
