Old February 19th, 2009, 14:35
tigtag tigtag is offline
Sagging leaf springs
I have a 97 XJ with 250,000 miles on it. The leaf springs are sagging in the back a bit. I'd like to be able to go up a couple of tire sizes to 30's but don't want to deal with the problems (or $$) that come with a suspension lift. Would replace the leaf springs with OEM equipment work or should I just put on a shackle lift? Any other ideas?
Old February 19th, 2009, 14:41
TheAlmightySam's Avatar
TheAlmightySam TheAlmightySam is offline
Re: Sagging leaf springs
OE springs are pretty cheap at Quadratec. For the price, though, you can get the HD leaves that net you about 2". Add some 2" coils, new shocks, and a new brake line, and boom, you've got a cheap lift. Adding a shackle would be a fine temporary measure, but often times the longer shackle changes the leverage on the springs, causing them to sag even further.
That said, I ran 30s on my Cherokee with no lift and sagging springs for years with no trouble at all.
Old February 19th, 2009, 14:49
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Another possibility if you just want to restore original OE height would be to add a leaf. A search here should come up with some good info on this, and maybe even some pictures (the stuff is there, but I don't know how well the search will find it). I've done this twice using a leaf from an old OEM spring pack cut down, and it makes for a nice cheap height restoration if you have, or can get, a set of old springs to carve up. If you have any friends in the area who have built up trail rigs, there might be some OEM springs to be found.
Edited to add: I would heed Sam's caution about shackle lifts on old saggy springs. I noticed when I recently added a leaf to my 99 (with 220+K miles), that there was a good bit of actual wear on the leaves, and that makes them saggier and a little softer even if they haven't deformed.
Old February 19th, 2009, 15:00
KaiserMan's Avatar
KaiserMan KaiserMan is offline
I just put in a second set on main leafs to my stock spring packs, and added in some home made 3/4" zero rate aal's and got a full 2" over stock height. I was sagged 1" below stock height so I actually got 3" of lift.
The 2nd main leaf firmed up the rear springs nicely, but still rides great.
Old February 19th, 2009, 15:08
winterbeater's Avatar
winterbeater winterbeater is offline
If your trying to save $$, tear your leafs down, inspect for damage, and add a few leaves from the junkyard. Just bring a tape measure to the JY.
Sagging leaf springs jeepdeez OEM Tech Discussion 6 December 15th, 2008 20:17
sagging springs atreyuBLUEXJ Modified Tech Discussion 3 January 11th, 2006 14:00
How do I tell if my leaf springs are sagging? IdeaMan Modified Tech Discussion 11 January 11th, 2005 17:46
Sagging Springs nosajwp OEM Tech Discussion 6 October 14th, 2004 09:43
Sagging Springs yardape Modified Tech Discussion 1 July 31st, 2003 23:45
