Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Grand Cherokee > ZJ and WJ Grand Cherokees (1993 - 2004)
ZJ and WJ Grand Cherokees (1993 - 2004) Technical forum for the classic ZJ and WJ Grand Cherokees.
Old May 5th, 2021, 10:21
smokeyyank smokeyyank is offline
Re: Project Potimus
Not a ton new but I did get new axles I'll eventually put in. Running a HP44 and 9. Will probably go with 4.56's and 35's. Do links for the suspension.
Old June 23rd, 2021, 11:48
Re: Project Potimus
Picked up four brand new Summit machine joints for links. Things are monsters
Old June 27th, 2021, 16:04
DaveCallis DaveCallis is offline
Re: Project Potimus
Damn! That looks good! How much did you get it for?
Old June 28th, 2021, 06:42
Re: Project Potimus
Practically free. All four for $100. Normally each one is $100
Old January 18th, 2022, 17:17
Re: Project Potimus
Got around to taking care of some things. First was the battery and installing new 2g wires. I ordered them a while ago from Jeepcables.com. Overall, really great kit super well built. My issues are the length of the alternator wire is about 2 ft too long and a few of the connections needed to be bent in order to fit. Install took about 2 hours of which most was tweaking things and taking out the old cables. Battery I upgraded to an Odyssey. After burning through a few of the Costco Interstates decided it was time. They just haven't lasted and I've been wanting to get a AGM battery. After everything is done really happy with it. Starts up quick regardless of temperature and idle has smoothed out as well. Old wires were beat up so something to be excepted.
Next up was finally replacing the entire power steering system. The old box was starting to get really sloppy and the pump was on it's way out. Not to mention the leaks from all the old hoses. For the pump I got a new ones from Lares. Ran one in my XJ and never had problems. For the box I went with a redhead.
Steering is drastically improved. Box is nice and tight and turns smooth. No more leaks either so huge win.
Old January 18th, 2022, 22:28
Ralph77 Ralph77 is offline
Re: Project Potimus
That was one of the reasons I decided to make my own for my '00 XJ.
Cause of the way the PDC is set up I was able to ditch the fuse holder and put it in front of the PDC.
Plus using 45 and 90 degree lugs here and there let me route them a little cleaner too.
Project XJ WUS Renegade0401 NorthWest Chapter 19 January 1st, 2015 13:59
My next project. BoringDave NorthWest Chapter 9 July 6th, 2012 14:25
Looking for project MJ dave92cherokee SEC For Sale / Wanted Forum 17 June 2nd, 2010 05:35
Project 100$XJ and Project JEEPSPEED AZXJ Arizona Chapter 23 August 23rd, 2007 12:57
91 4dr project 33s, 91 4 dr project stock Rockhound For Sale: Private Party Only. XJ ITEMS ONLY 1 May 8th, 2007 20:13
