Old May 1st, 2014, 18:01
petvet92's Avatar
petvet92 petvet92 is offline
Alternator Upgrade
What is the best alternator to replace the OEM in a 95 4.0L high output XJ with a winch, lockers, on board compressor and auxiliary lights?
Old May 1st, 2014, 19:46
the_weirdo's Avatar
the_weirdo the_weirdo is offline
Re: Alternator Upgrade
Running a 130 amp alternator from a Grand Cherokee is an easy upgrade. Do a search for it.
I'm not a complete idiot, some parts are missing.
Old May 1st, 2014, 19:57
ingenio ingenio is offline
The durango alt upgrade is an easy one
It requires some minor grinding in the bracket and in the block.....
I did it couple months ago
Upgraded mains cables are suggested
Search for 5-90 in naxja forum
Old May 2nd, 2014, 07:30
O-Gauge Steamer O-Gauge Steamer is offline
My local Alternator shop discovered a 200 Amp alternator that, mostly, bolted in. The mounts had to be opened up a bit but that is a well known necessity for all of the high output Alternators.
Cost wise for the new alternator, it was only a few dollars more than what NAPA wanted for a remanufactured 130 Amp.
The fusible link was replaced, as part of the installation, with a 00 gauge wire connecting via a fuse to the PDC. IMO, one of the most overlooked portion of the Alternator Upgrade mod is the fusible link. What good is the high capacity Alternator if the fusible link is still stock. Not only will the wire size be flat wrong... The link should blow out when the Alternator's output is pushed.
My system can deliver 160 Amps at idle and 190 Amps at 1500 RPM which is not too shabby at all...
If you have a small, independent, shop near by, check them out. Be amazed at just how reasonable the new part cost is.
What drove the replacement in my Heep was three 10" electric fans, an electric water pump, the winch and, I thought it might be nice to get full voltage to the headlights. Just for fun...
What was fun this winter was when I was asked to jump my neighbors Diesel Truck. My Heep was able to get his going with the Heep idling...
I am not a fan of used Alternators. For me, the piece of mind knowing that there is a warrantied part under the hood has value. More so than saving a couple of bucks...
Old May 2nd, 2014, 21:58
HuntFishCampXJRay's Avatar
HuntFishCampXJRay HuntFishCampXJRay is offline
Just wondering what kind of amp was that?
Old May 3rd, 2014, 15:52
SketchyWaffles SketchyWaffles is offline
Any chance you have a part number?
Old May 4th, 2014, 03:36
petvet92's Avatar
Thanks for the previous posts. I've seen some info on the Durango and GC upgrade, but want to avoid too much grinding. Anyone running a powermaster 170/110, or a mean green that's supposed to crank up to 200 amps?
Old May 4th, 2014, 05:53
techno1154's Avatar
techno1154 techno1154 is offline
Chances are both the Powermaster and the Mean Green high out put alternators are larger (have a larger case) than the OEM XJ unit which would be the same size of the Durango and Grand Cherokee alternator. The smaller units that have been modified to increase the out put produces low power at low RPM. You would be better off to just clearance the block and alternator mounting bracket and fitting the larger alternator which produces higher amperage at low RPM. I have done this on my XJ in 2004. Many others on this forum and countless other Jeep forums have do so successfully and with no adverse effects. There have been several write up here on on how to do it.
To answer your question,...Most on this forum avoid the Powermaster and Mean Green units because of the price,...$400+
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old May 4th, 2014, 06:56
OutkastBoss OutkastBoss is offline
I run a 160 amp 'rango alt and it isn't very hard to grind the bracket to fit.
Upgrade the mains and the fuse to go with it though.
Old May 4th, 2014, 07:22
Sure, plus a link to the thread where I installed the thing.
Nippondenso part #: DN13341NA200
Be advised, this is not s cheap part. Think $300.00 here... On the other hand, it has been spinning awa for the better portion of two years without any issues at all...
http://www.naxja.org/forum/showthread.php?t=1084088
92 Alternator Upgrade ?'s joshthib@comcast.n Modified Tech Discussion 7 August 3rd, 2020 14:09
WTB: XJ Alternator Upgrade jeepsrock SoCal For Sale 8 December 19th, 2013 11:05
Alternator Relocation / Alternator Upgrade Jamescad04 Modified Tech Discussion 6 April 1st, 2011 20:21
alternator upgrade mark91xjbeef Modified Tech Discussion 2 March 18th, 2011 06:31
Alternator upgrade Erik Litchy OEM Tech Discussion 3 June 15th, 2003 21:37
