Old September 7th, 2006, 20:03
Steve-o94XJ Steve-o94XJ is offline
Securing replacement (aftermarket) radiator...
Greetings all.
Frequent lurker, infrequent poster.
I just finished swapping out my stock radiator (112K on the odo) for a CSF 3-row.
While replacing it, I noticed that the CSF had several threaded studs sticking out of the top, but none matched the holes in the (stock) bracket that sits on top of it. The stock rad. had a couple studs that, from what I remember, were secured by a couple nuts (i.e. they matched up with a couple of the holes in the bracket).
Anyway, I Dremel'd the studs off the CSF so the bracket would seat on top of it. Of course the bracket is still secured by 4 bolts (2 on each end) plus the 5 torx-head screws in front, so that's fine.
However, I noticed that there's a little play in the radiator. It seems secured, but I can still move the top of the radiator back & forth a little bit.
I suppose I could have drilled holes in the bracket to match up with the studs on the new rad., and secure with a couple nuts, but it's too late for that now.
Any thoughts? Or should I just forget it? It doesn't move around much, but I'm wondering if this could be a problem down the line.
Thanks...
Old September 7th, 2006, 20:09
5-90's Avatar
5-90 5-90 is offline
Re: Securing replacement (aftermarket) radiator...
At least on RENIX, there are a couple "cushion mounts" - these are located on the studs atop the radiator (secured with nuts,) and then there are studs that stick out of these that are secured to the upper crossmember with nuts.
Did you notice cushions on top of the old radiator? They would have been (probably) about 2" wide and about 3-1/2" to 4" long...
5-90
Aftermarket radiator BIG-G Jeep Street and Performance 40 July 8th, 2005 13:42
Aftermarket XJ radiator xj-grin Wanted: Private Party Only 3 December 14th, 2004 10:16
Best aftermarket radiator for 2001 XJ... RockRod Modified Tech Discussion 11 July 5th, 2004 23:09
Aftermarket radiator users woody431 Modified Tech Discussion 12 June 5th, 2004 18:49
Best aftermarket radiator ReBeL XJ Modified Tech Discussion 3 November 13th, 2003 22:49
