Old July 22nd, 2019, 20:49
mhead mhead is offline
Re: help oring filter adapter , still leaks after instaling new orings?
Update on o-ring install: I've operated my XJ now 3000 miles and for 3 weeks daily. No leaks! Looks like the o-ring replace holds pressure. I've got lots of sets of these o-rings. Maybe I'll swap them at each oil filter change.
And the new o-rings have cured my persistent oil leak.
Symptoms of my leak were oil on the ground of course but I always saw oil right on the outboard lower edge of the oil filter adapter. Oil on the starter motor as well. All dry now.
Mike
oil filter adapter shameless defect OEM Tech Discussion 10 June 26th, 2006 17:28
oil filter adapter scotttruhart OEM Tech Discussion 4 March 15th, 2006 19:54
4.0 Oil Filter Adapter REDSWAG OEM Tech Discussion 17 January 24th, 2006 00:15
89 4.0 leaks oil, pan, filter housing, main RangerRick OEM Tech Discussion 11 December 8th, 2004 16:17
Oil filter adapter? Jeepster4wd OEM Tech Discussion 16 February 27th, 2004 01:15
