Old October 18th, 2007, 08:56
selarep's Avatar
selarep selarep is offline
Securing the Sound Bar
I installed a sound bar in my XJ a while back and I didnt get a chance to get the little plate that secures it to the overhead. Is there anything I can do to secure the center of the bar to the over head? at the moment it just sags down at the center.
TIA.
Old October 18th, 2007, 12:13
Pigpen's Avatar
Pigpen Pigpen is offline
Re: Securing the Sound Bar
Go Bulldogs,
The little plate is just kind of glued in and the cargo area light screws in to it to support the center of the sound bar. Can you fab up a plate and then screw in to it.
Side note, I spent some time out side of Clovis (ya ever hear of Wonder Valley Ranch?)
Good luck, maybe sombody else will chime in.
Pigpen
Old October 18th, 2007, 12:27
selarep's Avatar
yup I've heard of wonder valley, clovis is cool.
Thanks, I'll just fab something up and use some epoxy to secure it to the overhead.
Old November 16th, 2007, 18:12
selarep's Avatar
epoxy didnt work, any one have any other ideas? Its about to snap just hanging there overhead...
Old November 17th, 2007, 03:11
jabird jabird is offline
I tried every epoxy I could find, then I used some "LIQUID METAL" and it hasnt saged since.......
Old November 17th, 2007, 05:20
sflier sflier is offline
Mine from the factory was secured my two little pins that screwed into the back roof support (the screw only went in about 1/8" into the the roof support). When I redid my interior, those fragile pins broke taking them out so I just bought a couple of small stud-like things from our local hardware store. I'm not sure that it's called but it has a metal screw on one side and a standard small bolt on the other. I screwed the metal screw side into the hole (just snug as to not poke into the roof itself) in the roof support and secured the center of the sound bar with a nut threaded onto the other end. If you don't have a domelight to use (which also doubles as the center support bracket for the sound bar), you could probably mock something up using a piece of sheet metal. I would not recommend glue if you ever plan on removing it in the future.
Old November 17th, 2007, 20:21
JEEPZZ's Avatar
JEEPZZ JEEPZZ is offline
You could try to fab something up or search for one in a boneyard.
Securing replacement (aftermarket) radiator... Steve-o94XJ OEM Tech Discussion 1 September 7th, 2006 20:09
Sound Bar for 97 XJ XJBandit For Sale: Private Party Only. XJ ITEMS ONLY 8 June 20th, 2006 21:59
What is a sound bar? montanaman OEM Tech Discussion 17 March 14th, 2006 20:54
Securing Jeep to U-haul trailer......questions, please help asap! Safari Ary Non-Tech / Off Topic 2 August 7th, 2003 19:20
