Old September 13th, 2019, 20:10
CJ'sXJ CJ'sXJ is offline
Re: Bad gas mileage 10-11 MPG
I didn't see it mentioned, pull the vacuum line to the fuel pressure reg. These are known to slowly lose the diaphragm and start leaking into the vacuum line. If it's gone you will have raw fuel in the line. Good luck getting it figured out!
Old September 13th, 2019, 23:04
paulhead's Avatar
paulhead paulhead is offline
I overtighten $#!t
location of pressure regulator?
“Lead me, follow me, or get out of my way. ”
-Gen. George S. Patton Jr.
Back at step 1, bought a YJ, an XJ going under the knife....
Old September 13th, 2019, 23:09
paulhead's Avatar
I overtighten $#!t
Also how do you use propane or smoke? Assume propane getting sucked in vacuum leak and increasing idle? Sorry, don't know.
Old September 16th, 2019, 09:36
devildog0's Avatar
devildog0 devildog0 is offline
I've never had luck using propane or the like to find smaller vacuum leaks. I built a smoke tester for about 50 dollars and love that thing. I found a few very small pinhole leaks using that device.
Here's one example.
https://www.youtube.com/watch?v=Np_duzsaZxI
Here's the one I built which was a little more hack job than others haha. I used a tube of epoxy for all the fittings. If I build another one I'll put the fittings in the side instead of the lid.
https://www.youtube.com/watch?v=29oXZ1sFPEY
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old September 20th, 2019, 13:31
paulhead's Avatar
I overtighten $#!t
So I finally got around to messing with the jeep, meanwhile thank you guys for flooding me with answers. Some suggested that O2 sensors could be bad and not read codes. So I ran am OHM test across the 2 white wires on the sensor and got 3.5 which is below specs. Gonna swap it out and see what happens.
Old September 20th, 2019, 13:36
paulhead's Avatar
I overtighten $#!t
Also do I need to unplug the battery and reset the brain or anything?
Old September 20th, 2019, 13:54
asymptonic asymptonic is offline
Yes, that is worth doing. Disconnect both battery terminals and touch the cables together for 5-10 seconds.
1998 4.0 I6, AX15, NP231
Old September 20th, 2019, 16:16
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Make sure to buy NTK/NGK O2's and NOT Bosch.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old September 20th, 2019, 16:26
paulhead's Avatar
I overtighten $#!t
Done and installed
Old September 23rd, 2019, 23:18
paulhead's Avatar
I overtighten $#!t
1/2 tank of gas later and same, 10 mpg. Blew a hole in my muffler this morning and replaced it with a Flowmaster. Could a crappy muffler affect mileage? Didn't' notice a power difference after the switch so I don't think it was choking it.
Old September 24th, 2019, 08:01
RCP Phx RCP Phx is offline
Not to likely but a clogged cat will.
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
I've read a bad catalytic converter can, but are you noticing acceleration problems to?
Old September 24th, 2019, 08:14
Tim_MN's Avatar
Check the basics, …... Nearly all XJ's have or will have a cracked exhaust manifold.
That would run rich.
Old September 24th, 2019, 10:57
paulhead's Avatar
I overtighten $#!t
dude inspected cat and said it was good. back to the drawing board
Old September 24th, 2019, 12:55
Could a bad temperature sensor be a possibility? Just spit balling.
Why is my gas mileage so bad walkerja191 Modified Tech Discussion 33 January 6th, 2009 21:52
gas mileage mitsumotors Modified Tech Discussion 61 December 27th, 2007 20:33
Better mileage icebergmedic Modified Tech Discussion 6 November 21st, 2007 13:23
Where the gas mileage go? balor OEM Tech Discussion 5 November 2nd, 2005 17:07
No cat mileage ParkCityXJ Modified Tech Discussion 8 December 29th, 2004 00:10
