Old July 17th, 2019, 17:46
ehall's Avatar
ehall ehall is offline
any tips for timing chain
I'm planning to replace the timing chain on my pos in a couple of weeks and looking for tips. The last time I did this (years ago) the motor was on a stand, this time doing it while the motor is still installed. Do I need to pull the radiator? Anything special about the gap between the timing cover and oil pan gaskets? I already bought a Mopar chain, the Fel-Pro TCS 45458 gasket kit, a Sealed Power guide, and a Dorman harmonic balancer (just to reset the maintenance interval).
Thanks
my '91 beater rebuild
Old July 17th, 2019, 17:53
Anak's Avatar
Anak Anak is offline
Stranger
Re: any tips for timing chain
I think you have chosen a wise course. The rubber in the original dampeners is in pretty poor condition by this time.
What is the Sealed Power guide?
Is that the replacement for the used-to-be-rubber chain dampener? Or is it an alignment tool for the cover?
You probably want both of the above.
I don't think you need to remove the radiator. IIRC the puller clears below the radiator. But all the accessories have to come off the passenger side of the engine. If you have AC you will want to support the compressor off to the side so you don't have to open the lines.
Baby it's cold outside.
RCP Phx RCP Phx is offline
Mopar chain(and gears) was your first default, send it back and buy a good chain.
Old July 17th, 2019, 18:44
ehall's Avatar
what brand do you recommend? Haven't had good experience with Cloyes in the transfer case
Old July 18th, 2019, 00:17
For the best get a Roll-master.
Old July 18th, 2019, 08:08
cruiser54's Avatar
cruiser54 cruiser54 is offline
No need to remove the radiator.
Might wanna get a new rubber block while you're at it.
Who knows on parts quality these days?
Most every name brand company has outsourced to C.R.A.P.
Chinese Replacement Auto Parts
Old July 18th, 2019, 09:59
chickenbot chickenbot is offline
P5249519 is the jeep part number for the cloytes double chain kit
Old July 18th, 2019, 10:00
and it comes with a 2 year unlimitied mile warranty
Old July 18th, 2019, 11:54
md21722 md21722 is offline
The factory chain and sprocket setup can last hundreds of thousands of miles. Unless you are running some kind of racing Jeep I don't see why you'd need to improve upon it? I have changed them in both of my 4.0's when I pulled the timing covers off to reseal the lower end. One Jeep had 340k on it when I did it, and I think even the sprockets looked fine. I probably could have slapped it back together but I curious to compare against new. The other Jeep had 185k and I'm it's forth owner. The chain did not appear to be excessively stretched but there was some grooving on the sprockets. I used Mopar parts on one and by the time I got to the other one I could not get a complete set from Mopar (at least one part went NLA) so I used a timing set from NAPA.
Old July 18th, 2019, 18:36
ehall's Avatar
Should be less than 100k on this motor but it has overheated a few times, pretty sure the chain is stretched but guessing the sprockets are alright. Maybe I should replace them anyway
Timing Chain srpope80 OEM Tech Discussion 20 October 28th, 2012 11:54
WTB timing chain set 2stix SoCal For Sale 3 April 22nd, 2012 16:54
timing chain tj'sxj OEM Tech Discussion 3 February 3rd, 2012 04:45
Timing Chain HELP !! gmcelroy OEM Tech Discussion 0 October 28th, 2006 18:46
Timing Chain Danwa OEM Tech Discussion 8 July 21st, 2004 01:21
