Old April 10th, 2017, 12:35
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
Re: Renix hard to find parts sources thread
"Jeep" logo OEM fog light covers.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 Stock-ish
SoCal Chapter Past President
Old April 10th, 2017, 14:45
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
I think I have a pair in my parts pile.
They won't fit my LED's. Ha
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old July 29th, 2017, 10:59
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Hoses for the Renix coolant bottle to pipe T's and from the heater core to the pipe Ts, some brilliant person designed them with two different hose IDs on each end.
The bottom hose on the coolant bottle is easy to find and cheap ($10), but the heater core hoses and the side of the coolant bottle hose to the pipe T is made of Unobtainiam right now.
8" of hose and they want $15-$40 each delivered.
I bought 2 sets delivered for about $4 each last month from one of our Jeep aftermarket vendors, but their entire stock was hard like concrete and all had to be sent back to China as they damage the heater core nipples during installation and clamps could not squeeze them they were so hard, like plastic.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old July 30th, 2017, 12:50
Strokermjcomanche Strokermjcomanche is offline
Just get some 1/2 inch heater hose and spray some wd40 ( or equivalent) on the tee side , it will slide right on .... Done this for years without a single problem.
Old July 30th, 2017, 12:53
And you can use the 97 and newer heater hoses and lose the heater valve ,or use the same 97+ hoses and cut them to accept the heater valve if you wish to keep it
Last edited by Strokermjcomanche; July 30th, 2017 at 12:54. Reason: Quoted my other post
Old July 30th, 2017, 13:30
Ecomike's Avatar
NAXJA# 2091
So the T-side is a larger metal OD than the heater core on the Renix?
Old July 30th, 2017, 13:40
I was referring to the expansion tank side to tee .
Old July 30th, 2017, 14:09
Ecomike's Avatar
NAXJA# 2091
Ah, those are easy to find and cheap for the Renix. It's the two that go from the actual copper heater core to the two T's.
I am seeing $48 prices for them, LOL. And I am not 100% sure, but they seem to be two different pipe sizes on them also.
Old August 4th, 2017, 19:27
Ecomike's Avatar
NAXJA# 2091
I found the Renix heater core, inlet and outlet to t-fitting hoses, they are .55" X .62" ID
OMIX-ADA Heater Hoses 17116.65
About $40 cheaper if you have this part number LOL.
Google it, many stock it but non pull it up on a heater hose search, just a part number search using the above number.
Old August 6th, 2017, 09:24
Bent's Avatar
The straight steel tube that comes out of the top left of the water pump for the heater hose. The Renix heater hose has a formed "L" to accommodate the straight outlet. The available HO version it bent to 90 to wrap around the head and valve cover pointing towards the back of the engine.
It really not a big deal to cut the heater hose, but still.
Old August 6th, 2017, 16:00
Ecomike's Avatar
NAXJA# 2091
I think I used a 3/8" galvanized sch 40 pipe nipple, 12" long ages ago. I thought I saw it online recently, but maybe what I saw was the HO version you mentioned. I have a used spare, which is now more valuable than I thought.
Old April 1st, 2018, 14:52
Ecomike's Avatar
NAXJA# 2091
Just found out that no one has the Renix NSS Neutral safety switch with the Renix QC anymore. They are all trying to sell the HO NSS with the new style connector, so you can get the switch (I am assuming it dod not change), but you will have to rewire/ swap/modify the connector ends...
Old April 2nd, 2018, 06:41
cruiser54's Avatar
cruiser54 cruiser54 is offline
What year did they change?
Old April 2nd, 2018, 07:02
Ecomike's Avatar
NAXJA# 2091
Not 100% sure, but I suspect they switched connector ends in 1991, definitely by 1996. Ebay, out of China still has the old 1980s Weatherpack connector parts and tools to make our own connectors, but I discovered last year there are two style 3 pin flat ones!!!! One for the MAP sensor and one for the TPS, and the slots are 180 degree reversed. I had to use an Exacto knife to cut slot in a TPS style connector to use on the MAP sensor harness side side to adapt it. No big deal, but now I wonder how to identify which one from China fits what LOL. I stocked up on the 2,3 and 4 pin ones for the TPS and O2 sensors about 10 years ago. Thinking it is time to do the others now, IAT, NSS, and so on.
Old April 2nd, 2018, 07:03
cruiser54's Avatar
I'm not sure it was 91 when the HO appeared.......
1500 page hard to find parts quide Ecomike OEM Tech Discussion 8 February 5th, 2019 18:04
Hard to find OEM parts brademerick OEM Tech Discussion 10 August 5th, 2010 14:14
Why are Cherokee parts so hard to find? Doboy71 OEM Tech Discussion 29 February 3rd, 2009 18:05
New Source for Hard-to-Find Parts Sand-Dog OEM Tech Discussion 2 March 24th, 2006 08:14
