Old August 4th, 2010, 20:18
brademerick brademerick is offline
Hard to find OEM parts
I've got a 1999 Cherokee XJ and I need a proportioning valve for the brakes. The dealer has one for $106 and I was hoping to find one for less money. I tried NAPA, Carquest, O'Reiley's, Auto Zone, and Advance Auto but none of them carry it. I've also looked at several online compnaies but no one seems to carry it. Has any one got any ideas?
Old August 4th, 2010, 20:23
yossarian19's Avatar
yossarian19 yossarian19 is offline
Re: Hard to find OEM parts
You could probably get an adjustable prop valve cheaper
OR
go to a junk yard and pull one.
What is wrong with yours?
Old August 4th, 2010, 22:53
joe_peters joe_peters is offline
OR
Agree, salvage yard or a universal adjustable one. Google adjustable proportioning valve.
Old August 5th, 2010, 08:02
heyhar's Avatar
heyhar heyhar is offline
Do they go bad? I know they can get dirty from not changing fluid, but I've taken one apart, and there's not much to it.
Old August 5th, 2010, 08:11
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
I've never seen one go bad, honestly - unless you put dot5 in it and screwed up the seals, you can probably just clean it out and reassemble.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old August 5th, 2010, 08:24
heyhar's Avatar
Last summer, with all the relatively low mileage 'Clunker' XJs showing up at Harry's, we grabbed a few booster/MC/prop valve combos, and I opened up a prop valve, just to see what was in it. Seems as though just the slide to activate the warning switch, and some crud, which I guess could cover a port, and cause a malfunction. Clean it out, and all should be good.
My son recently purchased a 'power bleeder'. I tried it once, and my first reaction to it was 'Where have you been all my life!'. No more waiting for an assistant to come home. Gives great pedal feel. These ought to be on everyone's tool list.
Old August 5th, 2010, 11:22
Speed Bleeders rule!
http://www.speedbleeder.com/
Old August 5th, 2010, 12:31
heyhar's Avatar
Joe- I've used the one-man bleeder ferrules, but unfortunately, they were Dorman 'HELP' items, and one winter of PennDOT spraying their Magic Elixir on the highways before snow rendered them useless. They galled up as if they were aluminum. The piece I'm referring to is a PowerBleeder from motiveproducts.com. Basically a garden sprayer with all the right fittings. Does a great job, and you can do it by yourself.
Old August 5th, 2010, 13:17
LOL! Tunnel vision--I forget some people live where things RUST!
Pressure bleeders are cool, and there were a lot of times over the years I could have used one when working alone, but availability and price didn't make sense compared to gravity/vacuum/speed bleeders.
Old August 5th, 2010, 13:27
TerraWombat's Avatar
TerraWombat TerraWombat is offline
Speedbleeders are very robust and I've had no problems with mine on the salty NJ roads. I've had them on one of my cars for about 6 years now and they have produced the best results in terms of pedal feel of any brake bleeding method I've tried - including a vacuum pump and two-man bleeding operation. Quickest brake bleeding I've ever done, too.
Old August 5th, 2010, 14:14
ChiXJeff's Avatar
ChiXJeff ChiXJeff is offline
Curmudgeon
Speed bleeders are not power bleeders. They're a spring loaded check valve. BTW, they don't work if there's significant air bubbles in the line.
Power bleeders...... whether by vacuum, or by pressure, yah. VERY useful.
ChiXJeff
Lifetime member
"Jeeps are Cherokees. All other models are wannabes." Deb. K.
Why are Cherokee parts so hard to find? Doboy71 OEM Tech Discussion 29 February 3rd, 2009 18:05
New Source for Hard-to-Find Parts Sand-Dog OEM Tech Discussion 2 March 24th, 2006 08:14
dana 30 and c8.25 4.56 how hard to find? Shomsky462 Non-Tech / Off Topic 3 December 30th, 2005 18:11
where can i find or how hard is it too find ?? stu's jeep's OEM Tech Discussion 3 April 9th, 2004 21:42
