Old April 2nd, 2018, 08:31
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: Renix hard to find parts sources thread
The new style connectors, the new GM connectors were used on the 91 on the IATs, so I suspect it was 91. Why? Didn't the 91 TPS use the new GM connectors?
Originally Posted by cruiser54 View Post
I'm not sure it was 91 when the HO appeared.......
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old April 2nd, 2018, 09:30
Anak's Avatar
Anak Anak is online now
Stranger
Originally Posted by Bent View Post
The straight steel tube that comes out of the top left of the water pump for the heater hose. The Renix heater hose has a formed "L" to accommodate the straight outlet. The available HO version it bent to 90 to wrap around the head and valve cover pointing towards the back of the engine.
It really not a big deal to cut the heater hose, but still.
If my mind still works, the threads on the water pump on my '96 are 3/8" NPT. I didn't care for the rusting steel pipe that I had, so I swapped over to stainless steel. Stainless pipe nipples, couplings and elbows can all be had if you look in the right places. It is even simpler if you want to keep things straight.
The important piece is the fitting for the heater hose, and Performance Stainless Steel makes 3/8" NPT fittings: https://performancesst.com/product.p...9&cat=7&page=1
Baby it's cold outside.
Old April 2nd, 2018, 14:30
cruiser54's Avatar
cruiser54 cruiser54 is offline
The NSS connects to the harness near the trans, via a pigtail, not directly to the TPS.
Old April 3rd, 2018, 11:03
sjx40250's Avatar
sjx40250 sjx40250 is offline
Yup. '91 = HO
Old April 3rd, 2018, 11:20
cruiser54's Avatar
Originally Posted by sjx40250 View Post
Yup. '91 = HO
Yup. We all know that....
When did the NSS connector change though? Ecomike is only guessing.
Old April 3rd, 2018, 11:55
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
I'm 99% sure NSS connector on 4.0L is 96 down vs 97 up. I know they added another contact and wire for it at that point.
I'll have to check my 88 against a 94 harness I have, but I could swear it's the same 8 position, 7 pin Delphi (previously known as Packard Electrical Division, now known as Aptiv) connector. I believe it's actually a metripack not a weatherpack, but cannot guarantee I'm right on that without some research.
BTW: RENIX 4.0L ECU connectors are a metripack 100 series connector. So is the 96-down TCU connector. Discovered that last night working on a project - they are keyed differently of course.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old April 3rd, 2018, 13:25
cruiser54's Avatar
My thoughts also. The 96 to 97 split. Not Remix to HO split.
The TCUs are different at the Renix split though.
Old April 5th, 2018, 08:55
kastein's Avatar
For sure. At this point I think I have a TCU from every year range (87-90, 97, 98-01) except for 91-??/??-95 (power/comfort switch split I'm not sure about) and maybe 96 if it's different. Need to compare/contrast them at some point.
I have a big stock of RENIX 4.0L ECU connectors coming from Mouser on monday... will test fit them and post up part numbers if they fit. I doubt anyone but me will ever need this info unless they are building a RENIX harness from scratch, but at least it'll be out there.
Old April 5th, 2018, 11:13
cruiser54's Avatar
Ken, the TCUs should have different color connectors. Renix is blue and 91 to 96 tan?
Old April 5th, 2018, 21:22
kastein's Avatar
The 88 I have sitting here has a gray connector. I think I've seen red as well but not sure.
Old April 9th, 2018, 18:12
kastein's Avatar
Happy to announce that the RENIX ECU connectors I bought fit perfectly.
Part numbers:
32 way connector
12045575 - housing
12045889 - top TPA clip with retention clip
12045890 - bottom TPA clip
24 way connector
12047946 - housing
12047900 - top TPA clip with retention clip
12047901 - bottom TPA clip
You need one of each above to create a harness.
Terminals are 12146448 and 12146447. Each is for a different wire gauge range. I can't remember which is which, check the ​datasheets. All of them can be bought on mouser.com for cheap. If you're near Central Mass, buy me a couple beers and I'll give you a set, I got ten because I hate paying more for shipping than I did for my parts but only need 2 or 3 sets max.
Old April 11th, 2018, 06:03
cruiser54's Avatar
So, there's really not all that many parts we can't get.
All the trim and mirrors talked about are not exclusively Renix.
Old April 16th, 2018, 22:27
Buckshot62 Buckshot62 is offline
Does anyone know where to find renix era power window regulator and motor new ?
Old April 16th, 2018, 22:28
cruiser54's Avatar
It's not just rEnix.....
Old April 16th, 2018, 22:59
Rockauto.com has two in stock as of today for the drivers front 98.99 + shipping.
1500 page hard to find parts quide Ecomike OEM Tech Discussion 8 February 5th, 2019 19:04
Hard to find OEM parts brademerick OEM Tech Discussion 10 August 5th, 2010 15:14
Why are Cherokee parts so hard to find? Doboy71 OEM Tech Discussion 29 February 3rd, 2009 19:05
New Source for Hard-to-Find Parts Sand-Dog OEM Tech Discussion 2 March 24th, 2006 09:14
