Barnett Performance Products & T&J Performance Center
Manufactured by T&J Performance Center
PM or call (866) 502-9877 for any questions. Ask for Tom N.
T&J Performance Center Heavy-Duty Diff Covers for Dana 30, 35, 44 & 50 axles. While providing greater protection against rocks and other hazards, the extra 1/8-inch steel plating along the bottom of the cover also acts as a skid plate to make getting past obstacles much easier.
Dana 30 Part# BP-DT030
Dana 35 Part# BP-DT035 - Custom Order
Dana 44 Part# BP-DT044
Dana 50 Part# BP-DT050
$114.00
Steering Box Brace for 1984 to 2001 Jeep XJ Cherokees. A bolt on kit that allows the sway bar to stay in the stock location. The heavy duty design helps eliminate steering slop and prevents cracks at the box mounting points.
Part# BP-S1014
$79.95
This Heavy Duty front to back frame connector attaches to the front lower control arm frame bracket to the front rear leaf spring hanger bracket. Dramatically increases frame rigidity and prevents damage to the unibody. Product does not consume any ground clearance.
Part# BP-A0016
$299.95
The ZJ Frame Stiffener System was designed in response to the growing number of our customers who drive ZJ Cherokees. This system makes use of quality MIG welded, 120 wall tubing and can be easily welded to your Cherokee. The basic idea behind our ZJ Frame Stiffener is to reinforce the unibody by providing high strength steel bars that run along the bottom of the unibody and tie into the suspension.
Part# BP-A0016Z
$299.95
Conversion Shock Brackets for the front of the 1984 to 2001 Cherokees. This bracket bolts into the factory upper shock location and conversts the mount from a stem system to universal eyte mount. The kit will accommodate Bilstein, King, Swayaway, or Rancho shock absorbers.
Part# BP-S1005
$110.00
1984 to 2001 Cherokee interior bar kit. This kit is the perfect starter kit whether you are racing a JeepSpeed or going slow wheeling. Our system is made of 1.75 x 1.20 wall cold roll tubing and consists of (2) A pillars, (2) B pillars, (4) roof bars, and (14) floor mounting plates. Windshield bar & side impact bars sold separately.
Part# BP-XJCRLR
Was $899.00
Now Only $699.99
Windshield bar & side impact bars $35.00 each
Check this out! Barnett Performance Products is proud to introduce to you, the XRock Sway Bar Kit For Your 84-01 Jeep Cherokee. Consisting of a Chromoly Mounting Tube and high strength, heat treated steel Torsion Bar, this kit takes the beating. The XRock kit eliminates the factory sway bar to give you better suspension articulation and adjustability without hampering on highway performance. This kit includes everything you need for a simple bolt in installation. No Welding Required!
Partr# BP-XROCK
$475.95
Our D-30 Gussets help add piece of mind and strutural integrity to your high priced differential housings. Complete with c-flange and upper/lower control arm gussets, this kit aids in protecting and strengthening the most vital parts of the front differential housing. Each gusset is made from high strength, cold roll, mild steel and are ready to be welded to your ride.
Part# BP-DIFFGUSSET
$79.95
Introducing the newest addition to our Barnett Performance line of products. The Barnett Performance Products Rock Slider Protection System. This kit utilizes quality components and intricate MIG welding, to give you the kind of durability you have come to expect from the Barnett Performance name.
Part# BP-XJSLDR (requires Part# BP-A0016)
Part# BP-ZJSLDR (requires Part# BP-A0016Z)
$345.00
T and J Performance Center has been performing engine swaps in jeeps for many years. The owners of T and J, Mike and Tom Barnett found that no engine conversion just bolts in. In response to many letters the brothers have painstakingly engineered their Barnett Performance Products, universal, cut to fit, engine mounts for the small block Chevy 350.
Partr# BP-V8MM
Call For Price
