Old May 22nd, 2020, 20:48
ShoeterMcgav's Avatar
ShoeterMcgav ShoeterMcgav is offline
Bilstein shocks... whatchya runnin??
As the title suggests... just trying to get a feel for what people use on lofted xjs.
About my rig: lift is probably close to about 5.5” with mid arms upfront. Rock krawler spring I’m guessing as that’s who made the Adj arms initially. They were solid dom and the heim joints were seized so I redid them and have JJs both ends. So, I am looking for performance over comfort, but I don’t trailer my rig so it will see it’s fair share of pavement as well.
I’m looking pretty hard at 5125s.. from my understanding they are the same as 5100s but not are custom length? Where the 5100s are for stock ish rigs?
Mainly concerned with the front shocks for now...
I don’t have the rod mount (forget the name of this mod) at the top and have bar pin eliminators for the bottom ... so when I look at vehicle specific ie 5100s I’d need the front and the back, if that makes better sense?
SO, I currently have some ruff country’s that are about 25” extended 14” compressed... ideally I’d want the shock to not be limiting before the limiting straps, but I know I don’t want them to be bottoming out before the bump stops.
What valving is best up front? I think that’d help me narrow down the lengths.. not much options in 26” and 14”, so if I know valving I can go for what’s closest to what I got is my thoughts.
Thanks for any input
97 XJ lift lockers 35s mid arms 9"/hp30 trussed warn hubs wj brakes 1ton OTK 4.56s etc work in progress..
93zj BEAST 35s Claytons LAs 44/hp30 lockers bumpers headers etc $old
Old May 22nd, 2020, 20:50
Re: Bilstein shocks... whatchya gonna runnin??
Here I was thinking I could get 14”s of travel and extend my limit straps for more droop... don’t think that’s the case tho
Old May 23rd, 2020, 10:23
Evan03 Evan03 is offline
I'm not a huge fan of the 5100.
Does the 5125 have pin top. I think it has universal mounts on both ends.
I'd be more likely to run kyb monomax on my xj than 5100s the mobo max is stiff shock that works very well off road and controls body roll on road.
Look at shock lengths for dodge pickups they have a pin top but do have a 9/16 lower so bar pin elimanators would need to be drilled out.
Picture is of a monomax I bought for my 2002 dodge 3500. It ended up on the jeep and worked extremely well.
It has about 8.5" of shock stroke.
I guess I should not talk bad about the 5100 because I only have experience with them on my pickup that is 9500 lbs with welder and tons of tools on it.
Old May 23rd, 2020, 10:40
waxer's Avatar
waxer waxer is offline
5100's on the front and rear of my 92 XJ and they perform Grrrrrrrrrreat!!!!
6.5" of lift on my XJ.. No issues at all.
92 XJ - Too much crap installed to mention!!
N1WAX
Old May 23rd, 2020, 14:15
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
X2, 5100 all around. One of the best shocks available for a Cherokee. The only reason to upgrade from these imo is for a rebuildable model. 2nd to billys Ide run OME without hesitation.
Btw external reservoir look cool but I doubt you get your money out of them if your not speeding through whoops.
Fox have a good reputation to, I wouldn't mind running any, but the are costly.
Old May 23rd, 2020, 15:32
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Bilstein 5165s. 11.3" in the front and 9.8" in the rear, a big step up from the 5100s in ride comfort. Bar pin eliminators front and rear.
https://www.shockwarehouse.com/news/bilstein_5165.cfm
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old May 23rd, 2020, 18:00
Evan, I don’t run the pin tops in the front
Old May 23rd, 2020, 18:02
The 5165s were a consideration- from all I’ve read they are 5100s with a remote reservoirs... and that is only a benefit when running hard and fast to dissipate heat. There is only like a double shot glass of oil in them- if that.
From what I’ve read of course.
For double the price I think 5125 or 5100 should fit the bill
Old May 23rd, 2020, 18:04
Y’all found 5100s with non pin tops for the front- what vehicle do you search? The only ones I found in non vehicle specific were 5125s
Old May 23rd, 2020, 18:54
shop extend/compress length for your vehicle. just look for the eyelet versions. pending what you need you might be able to just look at pre selected rear xj models and base the correct size/ part# off that. Otherwise to the billy catalog!
Bilstein Shocks Serious Offroad Vendor Advertisements 3 February 22nd, 2016 07:48
Help please which Bilstein shocks?? spdyracer Modified Tech Discussion 7 January 21st, 2012 18:02
Whatchya' doin'? Ryno XJ SoCal Chapter 15 May 8th, 2009 07:25
what kinda shocks u guys runnin? smokeeaterXJ Modified Tech Discussion 8 May 5th, 2006 22:40
Whatchya gotta get done 4ward 2003 Winterfest, Attica Indiana 34 February 2nd, 2003 20:04
