Old May 14th, 2020, 03:42
stickandrudder stickandrudder is offline
currie antirock install question
Hey everyone, long time reader of the forums here, first post I think.
I'm thinking about getting the currie antirock setup that's XJ specific. I have a 5in lift with a rustys longarm.
Can anyone tell me how "bendy"or "floppy" the fender panels get once you cut the support bracket off the frame? The install seems straightforward, but that part I'm curious on. I can't find any info on it, and the thread where a guy posted pictures of his install, the pics have vanished.
I have stiffeners but it doesnt look like it would be an issue.
Thanks in advance!
Old May 14th, 2020, 06:43
jk_surgeonfish jk_surgeonfish is offline
Re: currie antirock install question
I just put this on a month ago and have not noticed any changes in the fender. I do have bushwacker flares so that may help with rigidity.
I love the anti-rock btw.... it drives like a completely different vehicle. A bit more body roll on the road but it does not change the way I drive. I can zip through a roundabout just fine. Only if there is a cross-wind do I find I am steering it more. Off-road it is smoother.... In the past I would disconnect and thought it was good. With the anti-rock it is smoother and just helps absorbs large bumps. Of course, off-camber is so much more stable. I no longer need to carry a spare set of shorts. LOL. Hope is works well for you.
Old May 14th, 2020, 16:52
Nimrod's Avatar
Nimrod Nimrod is offline
Degenerate Jeeper
I cut through the support on the drivers side years ago to accommodate a steering brace, and recently cut through the support on the passenger side to install an Antirock swaybar. It’s caused no issues at all. On the other hand, I also have Rusty’s steel fender flares, which add stiffness to the upper part of the fenders. Bottom line though, I wouldn’t worry about it at all.
Old May 14th, 2020, 17:16
bajabronco bajabronco is offline
I have the antirock installed, no problems at all with the fenders. I do have notch customs flairs installed as well.
Old May 16th, 2020, 22:12
Thanks guys so much for the feedback. I currently have bushwackers myself. I’m gonna pull the trigger on the anti rock, I’m sold!
XJ/MJ Currie Antirock *xj-man* NAC Classifieds 4 March 4th, 2016 17:29
Currie Antirock puttzer For Sale: Private Party Only. XJ ITEMS ONLY 1 December 21st, 2014 11:14
Currie Antirock...Will it do enough? Mute9937 Modified Tech Discussion 10 June 8th, 2013 08:30
XJ/MJ Currie Antirock Exxon Valdez Jeep Sierra Chapter For Sale 6 October 2nd, 2011 09:31
Currie Antirock install RedHeep Modified Tech Discussion 4 October 14th, 2010 22:22
