Old December 4th, 2008, 16:36
Brad79CJ Brad79CJ is offline
A Pillar and Roof Repair from Roll
Thanks for checking my post. I have a 98 4 door xj that was in a light roll and busted the windshield, bent the A pillars and the front part of roof. I am getting a good body shell for the parts to fix it. I am not looking to make it look really good. I actually don't care how it looks. I just need to know the proper way to weld the A pillars and top on so it will seal decent and be able to withstand a roll. For piece of mind I will probably put an interior cage in it. I have a 220v Lincoln mig to weld with. The previous owner has already done some cutting out of the roof that was smashed down (I didn't have the pleasure of tipping this one over).
Safety is obviously my main concern. I know I don't want to just cut the old pillars off and butt weld the new assembly on, but I would like someone with previous experience to give me some ideas of what works and what doesn't. Getting the doors to shut right is another challenge, but just as long as they latch, it'll be fine. I am going to use this as a trail project, but it will be on the road too and need it to be weather tight.
Anyway, thanks for reading and here are some links to pictures
Thanks
Brad
http://i135.photobucket.com/albums/q...J/IMG_4296.jpg
http://i135.photobucket.com/albums/q...J/IMG_4298.jpg
Old December 4th, 2008, 16:49
RCP Phx RCP Phx is offline
Re: A Pillar and Roof Repair from Roll
You want to mitre the cuts as much as "reasonably" possible(on the pillars).For any roof sections get a flanging tool if possible.
Old December 5th, 2008, 08:35
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Yellaheap has some good info - http://naxja.org/forum/showthread.php?t=917214
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old December 5th, 2008, 08:41
99xj4x4's Avatar
99xj4x4 99xj4x4 is offline
I rolled my XJ twice before I put a cage in it. You best bet is to get a port o power and all the attachment heads (pick up a harbor frieght cheapy) and strighten out what you got. If you cut any thing youll deffentally was to put a cage in before you drive it again.
I have a few pictures of the roll and body work here:
http://viewmorepics.myspace.com/inde...albumId=583816
Old December 5th, 2008, 09:45
Nice work on the red xj. That's a lot of bending to do.
I think I am going to run with the bend it, cage it concept. The PO did do some cutting but I will just straighten the pillars and then cut out the piece to plug the hole in the top. I'm not going to try real hard to make it pretty because its likely it'll get bent up later. Only trouble I see is getting the windshield hole close enought to get the glass in.
I'll post picks when I make progress.
Thanks
Brad
Bent & dented A-pillar repair write up. YELLAHEEP Paint and Bodywork forum 26 June 6th, 2007 14:33
Rust Repair in roof....and other places MaxxTraxx Paint and Bodywork forum 4 April 14th, 2007 19:31
A-pillar-only roll bar? Timber Modified Tech Discussion 4 November 10th, 2005 16:02
Tires/wheels, winch bumper, roll cage, roof rack dmtjeep For Sale: Private Party Only. XJ ITEMS ONLY 7 December 19th, 2004 10:52
Roll cage/Roof rack JT86XJ Modified Tech Discussion 6 March 31st, 2004 17:42
