Old April 5th, 2006, 14:31
J98cherokee's Avatar
J98cherokee J98cherokee is offline
Is my driveshaft supposed to do this?
Is the front driveshaft supposed to turn a little bit back and forth when the engines off and the jeeps in park? im talkin like half and inch back and forth. The rear doesnt move at all.
Old April 5th, 2006, 14:37
87manche's Avatar
87manche 87manche is offline
Re: Is my driveshaft supposed to do this?
that usually indicates a worn chain, of course there's a lot more questions I have.
What year and transfer case?
Are you trying to move the front D-Shaft with the t-case in 4wd or 2wd?
in 2wd the front d-shaft isn't hooked up to anything in the t-case, and the diff would let it move about that much. if you're moving it in 4wd then I would take a look at the chain in the t-case, sounds like it may be stretched a bit.
Old April 5th, 2006, 20:11
its in two wheel drive so i guess im alright... i just had the chain replaced almost 2 years ago
Old April 5th, 2006, 20:32
langer1's Avatar
langer1 langer1 is offline
Lets say this a new front diff should be .005" to .008" so .500" is a little loose.
Old April 6th, 2006, 21:16
desertjeeper's Avatar
desertjeeper desertjeeper is offline
NAXJA Member #1195
um... that seems like flawed logic. When rotating the driveshaft you stack-up all the tolerences in the axle (backlash, spider gears, axle splines) and all this gets multiplied by the gear ratio. Anyway, that may be a little more than, say a new axle but I don't think it's that excessive especially if it's got some miles on it and/or low gears.
For those that say it's too much, go out and try yours you might be surprised.
My front shaft has probably twice that much slack, but it has a lockright (which adds a lot of slop) and low gears.
Old April 6th, 2006, 21:38
KarlVP's Avatar
KarlVP KarlVP is offline
I know TJ's with the 231 are notorious for having slop like that. Mine "rattles" when you go from clutch in to clutch out. It sounds bad, but has always been that way.
Is it supposed to do that? XJ4x4 OEM Tech Discussion 5 December 29th, 2005 01:52
what tranny is supposed to be in my 86 wagoneer 86wagonman OEM Tech Discussion 9 November 17th, 2005 14:17
Are the reverse lights supposed to come on with the motor shut off? 90Pioneer OEM Tech Discussion 9 November 14th, 2005 16:47
