Old February 17th, 2008, 18:27
Achmed's Avatar
Achmed Achmed is offline
37's on the HP30
37's on an HP30 with 30 spline Alloy USA shafts and Alloy USA 4.88's. Opinions on durability?
Old February 17th, 2008, 18:28
NCCherokee's Avatar
NCCherokee NCCherokee is offline
Thumbs down Re: 37's on the HP30
not a chance...this would be iffy on a chromo'd D44
Old February 17th, 2008, 18:37
RyanM's Avatar
RyanM RyanM is offline
It would last for a while. Once you got dumb, it'd break somewhere.
Old February 17th, 2008, 18:40
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
Like Ryan said, Truss it and polish it up real nice and it'd last far as long as you take it easy. I'm gunna run 35s on mine once my order comes in.
In the end, as always, it depends on the terrain and your right foot.
I won't be going over 35s on my 30.
Old February 17th, 2008, 18:44
Oizarod115's Avatar
Oizarod115 Oizarod115 is offline
brother's been wheeling 35s on a 30spline chromo-d 30 for a while, only thing we've noticed is wheel bearings don't last forever on the road. a warn hub kit would go a long ways... or possibly just quality replacements (timken) instead of cheap ones
Old February 17th, 2008, 18:46
Ramsey's Avatar
Ramsey Ramsey is offline
waste of money, even a 44 is questionable on 37s considering it has the same size joints
Old February 17th, 2008, 18:57
ddeadserious's Avatar
ddeadserious ddeadserious is offline
You'll probably eat u-joints, but it's possible to run 37's on a d30. Like said before, it's not necessairly going to break, it's all dependant on the terrain and how much you like the skinny pedal.
Old February 17th, 2008, 19:36
Achmed's Avatar
My rear D44 is 35 spline Alloy USA.
Old February 17th, 2008, 19:37
jeepxj21085's Avatar
jeepxj21085 jeepxj21085 is offline
yea a dana 30 is ok i have been running one for two years with 35s and 4.56 gears new wheel bearings and ujoints when i did my lift i braced mine with a rustys brace for 30 bucks and stick welded it
baseballneal86's Avatar
baseballneal86 baseballneal86 is offline
He means a front 44.
Old February 17th, 2008, 19:47
uncc civilengineer's Avatar
uncc civilengineer uncc civilengineer is offline
To me 35spline shafts in a 44 is just a waste of $$.... just doesnt seem to offer much benefit over 30 spline chromo's... As for 37's on a D30... I dont know.. I'm running 37" sticky's on 44's though and it's holding its own pretty well...
Old February 17th, 2008, 19:51
Achmed's Avatar
isn't a front 44 pretty much the same as a d30 other than ring and pinion diameter?
Old February 17th, 2008, 19:59
Ramsey's Avatar
and ball joints steering options hubs brakes, yes
Old February 17th, 2008, 20:00
other than actual hubs, larger shafts, larger ring gear, larger brakes, deeper gear options............ If you're worried about breaking a Spicer 760x joint throw some CTM's or similar U-joints into it.. To me it's easier to replace a u-joint as opposed to a Ring/Pinion...
Old February 17th, 2008, 20:39
99xj4x4's Avatar
99xj4x4 99xj4x4 is offline
Theres a guy in our club w/ a XJ on 37, locked, 4.56s, alloy usa shafts, and he wheels pritty hard. Been all over Rubicon and Moab, even walked Esclator and never had a problem. It can deffentally be done, but you will have to keep a light foot.
WANTED. Gears for HP30/8.25 or HP30/44 green50gt Wanted: Private Party Only 0 February 20th, 2007 07:37
XJ on 37's in Azusa? IMORTL SoCal Chapter 2 January 21st, 2007 18:04
37's Avanteone NorthWest Chapter 26 October 19th, 2006 23:00
37's on D44 or D60 VegasAnthony Modified Tech Discussion 94 October 25th, 2005 22:34
37's + 4.56 = ??? YETI Modified Tech Discussion 4 November 16th, 2004 12:46
