stoneattic
- Honey Brook, PA
I'm trying to install the M.O.R.E rubber engine mounts and poly trans mount. Has anyone installed the poly trans mount? The holes line up the same as the orignal mount but the mount itself is wider (front to back) than the original mount and is up against the t-case to x-member bracket. So I'm wondering is this normal? Do I just give is a few whacks with a hammer and/or just force it up and let the nuts pull it the rest of the way?
