Old March 22nd, 2013, 10:12
anthrax323 anthrax323 is offline
WJ disc swappers - Akebono caliper questions
Just out of curiosity - are all WJ calipers made with phenolic (plastic/composite/whatever) pistons, or are there steel ones available?
I ask because I absolutely hate phenolic pistons. I've chunked my XJ front caliper pistons a few times with channel locks when doing brake jobs, but fortunately they still seal perfectly. Seems like all the Napa Akebono remans use phenolic pistons, which kinda sucks.
I haven't yet gotten a chance to look at a true OEM WJ caliper so I'm not even sure they ever made them with steel pistons. Worst-case scenario I'll buy some remans (or hit the junk yard), track down some steel pistons and just rebuild them myself.
Old March 22nd, 2013, 11:01
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
Re: WJ disc swappers - Akebono caliper questions
Why not just keep a thin piece of metal to put over the piston to protect it when trying to use channel locks?
Old March 22nd, 2013, 11:22
foxwar71 foxwar71 is offline
Cstop using channel locks and start using a c clamp. I like to toss an old pad to press on in there so I dont damge the piston too.
Old March 22nd, 2013, 11:23
SuperRA SuperRA is offline
Or use the old brake pad to protect the piston.
Old March 22nd, 2013, 11:27
Bryan C.'s Avatar
Bryan C. Bryan C. is offline
Use a screwdriver and pry between the old inner pad and the rotor before you take the caliper off.
Old March 22nd, 2013, 11:34
JohnnyTurbo JohnnyTurbo is offline
^ What he said... be sure to catch any brake fluid that might come out of master cylinder when you push back caliper pistons. If brake fluid was added with thin /old pads then it will probably overflow and just make a mess... I keep a turkey blaster in garage to suck up fluids from master cylinder, power steering pump. I usually pull out and refresh with new every oil change.
Old March 22nd, 2013, 11:56
Maurice Maurice is offline
You don't want to use channel locks on WJ calipers anyway because there are 2 pistons. With the calipers hooked up you'll be pushing one while the other comes out
Unless you're Shiva and you have 2 pairs of channel locks.
Old March 22nd, 2013, 13:36
souske's Avatar
souske souske is offline
snag one of these:
http://www.sears.com/craftsman-heavy...2&blockType=G2
Old March 22nd, 2013, 14:56
All valid and fair arguments - but can't a man just have a preference for steel pistons?
I guess I should ask this: did any of the Akebonos have steel pistons, or are they all phenolic?
Old March 22nd, 2013, 15:14
DeftwillP's Avatar
DeftwillP DeftwillP is offline
Why would you use channel locks?
Old March 23rd, 2013, 08:57
Most vehicles I've owned have had single-pot steel-piston calipers, so it's how I learned to compress them. Again, at this point I'm just curious if any Akebonos had steel pistons.
Old March 23rd, 2013, 10:01
souske's Avatar
dunno, my teeves did .
Old March 23rd, 2013, 10:19
Vanimal Vanimal is offline
mine too, and there is nothing wrong with teeves calipers.
Old March 23rd, 2013, 23:24
westvirginia24976 westvirginia24976 is offline
Just have to keep them clean.
Old March 24th, 2013, 07:34
sunburned sunburned is offline
Here's a link for the real ones: http://www.justforjeeps.com/akbrcakit.html
WTB: ZJ rear disc brake caliper bracket and backing plates Ben824 SEC For Sale / Wanted Forum 0 April 14th, 2011 12:18
D44 rear disc question - need caliper info old_man Modified Tech Discussion 7 September 25th, 2009 20:31
NJ - ZJ caliper brackets for rear disc conversion SRP For Sale: Private Party Only. XJ ITEMS ONLY 2 October 26th, 2006 06:24
DISC BRAKE CALIPER MOUNTING BOLT HEAD SIZE BUS0711 OEM Tech Discussion 9 April 27th, 2006 20:06
