Old July 2nd, 2008, 13:01
WheelinJR's Avatar
WheelinJR WheelinJR is offline
Difference in body sides between early and late model???
I am trying to gauge whether or not the sideplates we just made will fit late model XJ's.
Points of concern are whether or not the contouring of the panels is the same. Can anyone clarify?
Old July 2nd, 2008, 15:32
drifto77's Avatar
drifto77 drifto77 is offline
Re: Difference in body sides between early and late model???
Those look SWEET!!!
Cant answer the question BUT......
if ya send me some black diamond plate ones I'll test 'em out on my '99 for ya.
Old July 2nd, 2008, 15:35
cherokee chuck cherokee chuck is offline
yes , they are the same, you just won't need the rears. the door skins are the same panels.,just the bottoms of the quarter panels are different because of the bumper ends.
Old July 2nd, 2008, 16:03
drifto77's Avatar
Old July 2nd, 2008, 16:34
WheelinJR's Avatar
Great thanks!
I was 99% sure they were the same up to the fender well, then wasn't too sure on the back.
On the 97+ is this piece plastic?
If it is, you may be able to remove it and use the rear piece.
Old July 2nd, 2008, 20:59
no, it's not the same under the bumper tip. you might be able to use your piece if it covers enough but it's different, not smooth like 96 & earlier. remember 97 up flares stop at the bumper tip.
A ? for the late model guys...... hot_rod_hooligans OEM Tech Discussion 6 May 20th, 2008 08:21
Have a late model OEM swing away? smcdonaldaz OEM Tech Discussion 3 May 19th, 2008 16:14
late model AC problems whited OEM Tech Discussion 4 October 4th, 2006 11:28
Late/Early model bumpers karstic OEM Tech Discussion 3 May 15th, 2005 13:48
Late Model XJ Body Parts catyrpelius Wanted: Private Party Only 0 December 12th, 2004 14:10
