Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Tow Rigs and Trailers
Tow Rigs and Trailers Hey, not all of our Jeeps are great on the highway. Post here for tech related to getting your XJ to the trailhead.
Old August 16th, 2007, 19:04
jacdu jacdu is offline
Rough idle 88 cherokee
I'm new to new group. A question on my son's 88 cherokee. It has a rough idle, new plugs, cap&rotor, o2 sensor. Checked for vacuum leaks to no avail. Is there a way to read the trouble codes without a code reader. It's the 4 liter six
Thanks, Jack
Old August 16th, 2007, 19:08
dj's 2000 xj's Avatar
dj's 2000 xj dj's 2000 xj is offline
Re: Rough idle 88 cherokee
I had the same thing on my 88. I did the cap, rotor, plugs, wires. Then I bought some seafoam. Seafoam worked great, now getting around 20 mpg on good days. Try a search on seafoam.
Rate This Thread:
Rough Idle on new MJ Bucketheadben OEM Tech Discussion 6 June 6th, 2007 11:57
Rough idle barece OEM Tech Discussion 1 February 21st, 2007 15:15
ROUGH and I mean rough run/idle XJ_Xtreme OEM Tech Discussion 7 December 15th, 2006 09:30
90 cherokee rough idle/missing problem AZRockRunner OEM Tech Discussion 3 May 13th, 2006 17:35
Rough Idle, Rough Shifting. At wits end Dent Doctor OEM Tech Discussion 0 September 21st, 2005 14:04
