Old December 21st, 2005, 17:03
Mike1331's Avatar
Mike1331 Mike1331 is offline
Bright yellow sludge in ccv system?
My guess, this is a combo of clogged gunk from ccv tubing mixing w/ oil, and condensated moister in my oil at the moment. Am I right? The system used to just pump out the oil as do most renix systems. Now it looks like blended squirl piss. Its spewing into my cone filter and i have to clean it every other day its getting quite obnoxious. Just replaced a thermostat from the dealer and my xj won't get above 160. The thermo said 195 on it when pulled out of the box. Could a faulty water pump cause a car to run too cold. My water pump is leaking out the bleader valve at the moment it will soon fail. My water pump pully has play in it, so I will be needing to replace that as well. I know I should clean out the ccv system or get a new one to vacume in the proper direction but has anybody seen this before?
Application
87 4.0
dynomax
cone air
Old December 21st, 2005, 17:06
Mike1331's Avatar
Re: Bright yellow sludge in ccv system?
oops this should probably be in oem>
Old December 21st, 2005, 17:19
BingBing's Avatar
BingBing BingBing is offline
Usually condensation in oil will appear more white in color. Yours being yellow in color, i'd be concerned of coolant in the oil.
Old December 21st, 2005, 17:35
Mike1331's Avatar
Asside from blowing a head gasket how would coolent get into the oil?
Old December 21st, 2005, 17:40
funvtec's Avatar
funvtec funvtec is offline
cracked something or other
Old December 21st, 2005, 17:43
BingBing's Avatar
Cracked block, cracked head, warped head. Get the water pump changed A.S.A.P. then check for coolant loss or leaks for the next two weeks.
Old December 21st, 2005, 17:51
Mike1331's Avatar
Allright will do thank you.
CCV Parts at NAPA ("blowby" fix) pxs OEM Tech Discussion 38 April 20th, 2008 13:53
Abbreviations XJ_ranger Non-Tech / Off Topic 51 March 9th, 2005 05:11
Cooling issue fixed....new tip for burping closed system czidesigns OEM Tech Discussion 0 June 17th, 2004 20:57
CCV and Intake sludge Boonie Rat OEM Tech Discussion 4 May 19th, 2004 08:27
Silverstar bulbs XJguy Jeep Street and Performance 20 December 26th, 2003 17:46
