Old November 19th, 2005, 17:15
Running-Snail Running-Snail is offline
Transfer Case Sludge
My son has had a great time off-roading with his 89 XJ. The jeep came home with a college buddy, I changed oil and was topping off the transfer case (NP242) when I noticed the fill tubing came out with something looking like mud on it.
The short version: The boys stopped the jeep in a stream! Obviously sucked water in due to rapid cooling/vacuum. Rear seal is shot, front might be too. Pulled drain plug to have sludge drop out.
I've added fluid, gone for a short drive (in full-time 4 wheel) then drained the fluid - done this 4 times. Fluid is starting to look red now!
Any recommendations on flushing the transfer case? Should I run synthetic ATF in it (for detergent action)?
Old November 19th, 2005, 17:22
langer1's Avatar
langer1 langer1 is offline
Re: Transfer Case Sludge
What fill tube?
Old November 19th, 2005, 18:04
TheBlueSub's Avatar
TheBlueSub TheBlueSub is offline
Question Re: Transfer Case Sludge
Originally Posted by langer1
What fill tube?
probally a funnel
sry to try and steal the tread does anyone kno a way to flush the transfer case
Old November 19th, 2005, 18:07
ECKSJAY's Avatar
ECKSJAY ECKSJAY is offline
Water is dirty
Open it up and clean it out. That's the best way to 'flush' it if you're noticing sludge.
Old November 20th, 2005, 17:11
redsand187 redsand187 is offline
Maybe try a can of brake cleaner, use the little straw and spray whatever you can through the holes, fill run and repeat. That should work more effectively then just drain and refilling.
Old November 20th, 2005, 17:17
Gerr's Avatar
Gerr Gerr is offline
seafoam transmission treatment worked good for cleaning out sludge in my transfer case.(drain and filled with new fluid and the whole can of seafom tranny treatment drove for a week then drained and filled again with propper fluid again)
How many things wrong can you find in this transfer case? djinn OEM Tech Discussion 2 August 31st, 2005 06:37
Transmission & Transfer Case Towing Questions chilibill OEM Tech Discussion 2 July 1st, 2005 18:24
transfer case woes,.. BILLXJ Modified Tech Discussion 15 May 24th, 2005 15:25
Transfer case spline count info wanted. lunghd OEM Tech Discussion 4 May 2nd, 2005 19:54
transfer case linkage fabrication ideas,.. bxj Modified Tech Discussion 7 June 22nd, 2004 09:14
