Old April 21st, 2005, 14:45
imprtfightr imprtfightr is offline
Please help! Alternator/Battery issue
My 88 XJ. 2.5L Non AC with 74 amp alternator. The other day, I dorve home from work. Parked. About 10 minutes later, I went to move it intot he garage and the battery was dead. Charged the battery for a couple hours. Started right up. Went out next morning, started, drove to work. Drove home 8 hours later. Parked. Went to restart, and it was dead. I replaced the alternator and battery. It seems as though the alternator isn't charging the battery. I can watch the voltage drop while its running (after I jump start it).
Could it be the regulator? Where is it, how do I check it?
Old April 21st, 2005, 14:49
red91's Avatar
red91 red91 is offline
Re: Please help! Alternator/Battery issue
IIRC... the regulator is Built into the alternator.
Modified Arizona XJs in 4wheel Drive Magazine Feb issue. ashmanjeepxj Non-Tech / Off Topic 7 January 27th, 2005 14:17
MJ no start - gas tank vent issue? xjblue OEM Tech Discussion 0 September 27th, 2004 12:21
XJ and garage door opener issue? C_M Non-Tech / Off Topic 3 December 7th, 2003 18:09
Strange performance issue (long) thudson OEM Tech Discussion 3 June 20th, 2003 16:36
(UT) RS2477 Roads Issue Is Pressed by Gov. Leavitt Ed A. Stevens Land Use Forum 0 April 8th, 2003 22:55
