Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > SoCal Chapter
SoCal Chapter The SoCal Chapter covers Southern California and Arizona. Please post local topics here.
Old November 16th, 2011, 01:25
Darky's Avatar
Darky Darky is offline
When it rains...
This is wunderbar...truck acts up, now the Jeep is having very severe drivability issues. Stalling, massive overheating, rough idle, hard starting accompanied by rich smell. It's got me seriously looking at parting it out and starting over with something else. If the engine is dead, or it blew a head gasket, I don't have the money to put into fixing, rebuilding, or replacing the engine. The part out would be to get into something I can drive.
I'm going to take a look at it tomorrow, poke some things with a wrench, cuss, and pretend I know what I'm doing, and hopefully at least confirm or deny the head gasket. I mean, it's not like it's hot out at 10pm in 29 Palms during mid November...temp is somewhere around the 50's. Clutch fan works fine (minus shroud, but it didn't overheat when it was 70-80...on a longer drive, through soft sand, with less airflow through the radiator since I was going slower.
Old November 16th, 2011, 06:58
boostamante boostamante is offline
Re: When it rains...
Shitty man! Cuss at it for me would ya?
Old November 16th, 2011, 07:56
toyotawrench toyotawrench is offline
Damn dude sucks, when ur working on it call it a ni.. nincompoop yea that's it a nincompoop
Old November 16th, 2011, 13:20
GSequoia's Avatar
GSequoia GSequoia is offline
Everyone says I'm a jerk.
Hold up.
Did you get the recall a few years back? E22 if I recall? '96 XJs had bad code and had a way of plugging up the cat with bad O2 signals. Does it sound like it's constipated?
Prior President & Prior SoCal Chapter President
Originally Posted by Bent
Us normal people...
Old November 16th, 2011, 13:35
Papercut's Avatar
Papercut Papercut is offline
Here for the WIN!
Originally Posted by GSequoia View Post
Hold up.
Yup, I remember taking my 96 in and after I had to replace the o2. Was running way to rich plus misfiring.
Old November 16th, 2011, 13:38
Darky's Avatar
Hold up.
Yeah, I did that in 06-07ish. Got it back with a bad TPS that they said wasn't their fault. The cat was bad and they gave me a new one.
Old November 16th, 2011, 13:42
GSequoia's Avatar
Okay.
My '96 was melted down by the prior owner from not noticing the cat was plugged.
Us normal people...
Old November 16th, 2011, 14:04
Darky's Avatar
I went out and started it and it ran alright. Slight hesitation on revving, reasonably smooth idle, temp went up to 250 within 5-7 minutes.
Good news: no oil seen in coolant, no coolant seen in oil. Head gasket would appear to remain intact.
Old November 16th, 2011, 14:08
GSequoia's Avatar
Open the radiator, how much water movement do you see? Also you might have a seized thermostat, try pulling it and running. If the problem goes away put a new 195 degree 'stat in.
Us normal people...
Old November 16th, 2011, 14:19
Darky's Avatar
T-stat is reasonably new, within the last 4 months or so, and it was supposed to be a Fail-Safe one that would default to open if it went bad...but I know Murphy can touch anything. I'm gonna burp it in a little bit and dump some coolant in, it does look a little low, but that might be in part because of the overheating last night.
Last night, while the temp gauge was pegged, the heat was still cold.
Old November 16th, 2011, 14:33
jeeperjohn's Avatar
jeeperjohn jeeperjohn is offline
While that could be a bad heater control valve, that symptom points to a bad water pump.
Old November 16th, 2011, 14:42
GSequoia's Avatar
Or a big bubble in the system. I've also seen the HCV get jammed against the dipstick tube causing it not to open.
Us normal people...
Old November 16th, 2011, 14:46
Darky's Avatar
I've been contemplating a water pump for a while. It's been about 5 yrs or so.
I've also contemplated a bubble. That could cause it to be inconsistent with its overheating, right? The HCV is fairly close to the dipstick. It seems it used to be attached to the firewall somehow before the last one broke.
Old November 16th, 2011, 15:12
GSequoia's Avatar
Bubbles usually don't form by themselves, overheating can cause it or messing around with the system can.
Us normal people...
Old November 16th, 2011, 16:46
Darky's Avatar
I may not have gotten it burped properly when I did the thermostat. Could a bubble hide out for any length of time?
Rate This Thread:
It never rains, it pours... COWheeler Colorado Chapter 23 August 15th, 2011 23:47
When it rains ..... DJManche Colorado Chapter 27 July 10th, 2011 11:26
Bumpsteer/Loose Steering Only When It Rains Cherokeekid88 Modified Tech Discussion 1 September 23rd, 2009 08:45
When it rains, it pours!!! ColoradoRaptor Colorado Chapter 19 October 17th, 2008 20:08
Did a search, Tach doesn't work when it rains. BAs96XJ OEM Tech Discussion 4 April 24th, 2005 09:57
