Old March 28th, 2010, 08:39
MJR's Avatar
MJR MJR is offline
Re: Difference between early and late model AW4's
Originally Posted by MTY Mouse View Post
neither of the input sensor wires? sounds like the pulse per min or what ever then don't matter... doesn't speedo on my 89 pick up from the transfer case anyway?
No still have to deal with the output sensor issue. Those are for the trans controller. It doesn't use the the vehicle speed sensor.
Old March 28th, 2010, 19:36
lawsoncl lawsoncl is online now
Correct. The tranny output speed sensor is still needed, and needs to be 1 pulse per rev for the trans computer to work correctly. Have a look at the list of links I posted at http://www.naxja.org/forum/showthread.php?t=1006791
Old March 28th, 2010, 21:52
kastein's Avatar
kastein kastein is offline
No pictures that I have - but you can distinguish them pretty easily. A 98 or newer will have a sensor with (I think) two wires going to it up at the front near the bellhousing / shift cable bracket, while a 97 or older will have a mounting boss for one but it won't be machined out and there will be no sensor present.
My yard looks like Sanford & Sons.
Current crapcan fleet: LS swapped bobbed 79 J10 Honcho, 4x4 auto 4.0 8.25 swapped metric ton 88 MJ
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
What year model AW4's are compatible with a '97 cherokee ibrokeit OEM Tech Discussion 8 October 11th, 2009 15:49
Late dash into early XJ...I did search. XJRocket Modified Tech Discussion 1 January 3rd, 2009 07:50
Difference in body sides between early and late model??? WheelinJR OEM Tech Discussion 5 July 2nd, 2008 20:59
Late/Early model bumpers karstic OEM Tech Discussion 3 May 15th, 2005 13:48
