Old January 21st, 2010, 10:46
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
Difference between early and late model AW4's
I might be picking up a 99 xj that is said to have a bad tranny. I've looked on here but can't find anything mentioning it but just wanted to be sure before actually buying it. I've got a 93 xj country and wanted to know if it's a direct swap between the two. I know the TCM's are different but the only thing on the 99 that's bad is the tranny itself. I know there's also a difference between the output of the two between 2wd and 4wd but if that's the case I can swap the output from one to the other if need be.
Old January 21st, 2010, 11:45
98NWCherokee's Avatar
98NWCherokee 98NWCherokee is offline
Re: Difference between early and late model AW4's
I have heard there was a sensor change in 98 where a second sensor was added to the transmission. Others will probably chime in with the exact name but I've heard that older AW4's will not work with a post 98 chassis.
Old January 21st, 2010, 11:50
Coastie Coastie is offline
I don't think '96+ is interchangable with pre '96. I remember thinking the wiring was different because of the OBD switch and the TCM was intergrated with the ECU.
Old January 21st, 2010, 12:08
stephenspann27 stephenspann27 is offline
I remember reading there was a sensor added to the tail shaft..
Old January 21st, 2010, 12:24
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Changing output shaft is basically tearing the whole trans down, which in that case, you might as well rebuild the bad trans.. given that the case is still in good shape. But I do believe aside from the added sensor that it is pretty much bolt in
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old January 21st, 2010, 12:27
MrSimon MrSimon is offline
Its very rare to find a 99 with a bad tranny. There is a good chance the tranny itself is fine, and that something else is messed up .... TPS, TCM, low fluid, etc.
What exactly is the tranny doing that the guys thinks its shot?
Old January 21st, 2010, 13:10
Not sure what it's doing as he hasn't responded back yet. I wasn't talking about changing the output shaft more the tailcone to swap between 2wd and 4wd. I know the CPS mounts in the same place for both years whether the CPS itself changed. The only sensor that might have changed would be the speedo to interact with the 97+ CCD bus and OBD2. The NSS should be the same throughout and if not could be swapped over with ease, as far as the electrics go that go from the main harness to the trans itself is where I'm up in the air. I know physically it'll fit but wasn't sure about the connections if they're different or not.
Old January 21st, 2010, 13:54
MJR's Avatar
MJR MJR is offline
Swapping to 4wd requires transmission mainshaft replacement not just a tail cone to adpater swap on the AW4.
87-90
0.70:1 OD ratio
21 spline output shaft
Electrical connections early model
One transmission speed sensor (output only)
91-96
0.75:1 OD ratio
23 spline output shaft
97-mid 98
0.75:1 OD ratio
Electrical connections late model
mid 98-01
0.75:1 OD ratio
Two transmission speed sensors (input and output)
Old January 21st, 2010, 22:59
kastein's Avatar
kastein kastein is offline
ECU and TCU are separate through the whole life of the XJ family - you're probably thinking of the grand cherokee with the integrated TCU/ECU.
There is also the input/output sensor change as MJR said - and on the 93, the mounting boss for the input sensor won't even be machined out for you. Also the speedo sensor shouldn't be an issue, the electric VSS started in 91 and is mounted to the transfer case rear output housing (or in 2wd XJs, the output tailcone I guess) and in any case I am pretty sure I read somewhere that it's the same mounting as the mechanical speedo takeoff, just unbolt one and bolt the other in.
87-90
0.70:1 OD ratio
91-96
0.75:1 OD ratio
97-mid 98
0.75:1 OD ratio
mid 98-01
0.75:1 OD ratio
Thanks for the level of detail here - that clears up the confusion about the 98 one/two sensor switchover... I'll have to remember this in the future.
EDIT: What I'd do - if it sounds like it's an electrical/fluid issue, buy it and fix. If it sounds like a clutch pack issue, buy it and fix - you can get the rebuild kit for like $150something on ebay.
My yard looks like Sanford & Sons.
Current crapcan fleet: LS swapped bobbed 79 J10 Honcho, 4x4 auto 4.0 8.25 swapped metric ton 88 MJ
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old January 21st, 2010, 23:34
MJR's Avatar
MJR MJR is offline
A minor correction.
97
0.75:1 OD ratio
98-01
0.75:1 OD ratio
Old January 22nd, 2010, 05:19
Yah I'm still waiting on him to write back with what was wrong with it as I can pick it up with 183k miles for under a grand and engine, interior, and body are immaculate.
Old January 23rd, 2010, 14:01
lawsoncl lawsoncl is offline
One other comment. With the switch to two sensors, the rear speed sensor changed from 1 pulse/rev to 4 pulses/rev. Hence the need to swap the rear sensor rotor and sensor if putting a 98+ AW4 into an older setup that expects 1 pulse/rev.
Old March 28th, 2010, 06:28
MTY Mouse MTY Mouse is offline
Any pics of said change over? difficulty? Thinking of going from a 89' to 98 newer trans. ant electrical connnections that won't work?
Old March 28th, 2010, 07:17
MJR's Avatar
MJR MJR is offline
Putting a 98 into a 89 both connectors will be different but you can cut and splice. You just won't use the input sensor wires.
Via Easter Jeep Safari.
Old March 28th, 2010, 07:24
neither of the input sensor wires? sounds like the pulse per min or what ever then don't matter... doesn't speedo on my 89 pick up from the transfer case anyway?
What year model AW4's are compatible with a '97 cherokee ibrokeit OEM Tech Discussion 8 October 11th, 2009 15:49
Late dash into early XJ...I did search. XJRocket Modified Tech Discussion 1 January 3rd, 2009 07:50
Difference in body sides between early and late model??? WheelinJR OEM Tech Discussion 5 July 2nd, 2008 20:59
Late/Early model bumpers karstic OEM Tech Discussion 3 May 15th, 2005 13:48
