Old December 6th, 2016, 16:26
Overland's Avatar
Overland Overland is offline
Re: AX5 interchange between early and late
I'm into it the cost of fluids and my time. The early shaft appears to be 5 1/2" from the face of fifth. Close enough that I'll try to swap housings.
Old December 7th, 2016, 05:00
Overland's Avatar
All sealed up, no leaks, plenty of spline engagement.
Ain't no magic in the back of that box.
Old February 1st, 2017, 11:21
chalbert chalbert is offline
I have a march of 99 Cherokee Laredo. Does anyone on this thread know if they made an early/late model in 99?
Old February 1st, 2017, 18:04
Jeep Driver Jeep Driver is offline
Referring to the AX5?
No.
AW4 swap early to late spctrbytz OEM Tech Discussion 17 January 26th, 2018 20:43
early rear flare on late XJ? N8N_99xj Modified Tech Discussion 5 August 19th, 2012 13:04
Difference between early and late model AW4's dave92cherokee OEM Tech Discussion 17 March 28th, 2010 21:52
Late dash into early XJ...I did search. XJRocket Modified Tech Discussion 1 January 3rd, 2009 07:50
wnated early 90's late 80's xj rwallace Wanted: Private Party Only 1 January 7th, 2007 16:34
