- Newark, CA
Finally got everything back together on my, new to me '94. She's been used, but from the looks of things so far not abused with almost 170K on the clock.
It started out simple enough, replace the cat, TPS and fix the oil leak at the oil filter housing. As I went along that changed, quickly.
Started with the cat, sawsall is my friend. The muffler wasn't looking to good so out it came too. Started looking at the other parts of the exhaust system and found that the exhaust manifold was cracked at the collector, that's gotta go too. Figured the O2 sensor should get swapped out while I'm at it.
Got one of the APN headers, luckily they're somewhat local so I could go pick it up. Tore everything out to get the new header in and broke the steering pump reservoir in the process.
In the meantime I started to work on the oil filter housing. SKIM hooked me with the T60 bit to get the damn thing out. Got everything back together there and SKIM told be about the motor mounts being a root cause of header cracks. Looked at mine and found that they were toast, time for another trip to the parts store.
Cleaned up the intake, throttle body and other parts of the engine bay that I could get to now that everything was out. Didn't see much that was out of whack, luckily.
Reassembled the intake and exhaust then had to deal with the steering pump problem. Tried to order a re-manufactured one and ended up getting the wrong one. So I went to pick and pull and found one there. Since I had tore mine down I knew what was involved, so instead of getting the whole pump I just got the reservoir for $5. Much better than $100 for a re-man one. Also picked up a front turn signal housing since the left one I had was broken.
Got everything back together and torqued down, then changed out the fuel filter, air filter, oil filter, oil, plugs, plug wires, cap and rotor. Turned it over a few times and she fired up and purred like a kitten
I'm pretty stoked since I haven't done any serious wrenching in quite awhile.
Now off to get it smogged tomorrow. Hopefully she'll pass this time through.
Here's the master list of things done (so far):
Replaced Catalytic Converter
Replaced Muffler and Tailpipe
Replaced Cracked Exhaust Header with APN one
Replaced TB gasket
Replaced TPS
Replaced O2 sensor
Repaired Oil Filter Housing Leak
Changed Oil and Filter
Replaced Air Filter
Replaced Fuel Filter
Replaced Spark Plugs
Replaced Plug Wires
Replaced Rotor and Distributor Cap
Changed to 30 Speedo Gear from 34 Tooth to compensate for 33" tires on stock gearing
Replaced Motor Mounts
Replaced Steering Pump Tank and Fluid
Replaced TB gasket
Replaced TPS
Replaced O2 sensor
Replaced Air Filter
Replaced Plug Wires
