Differential skid plate interaction bar
Skipper51
I have a traction (not an interaction) bar and skid plate that used to be on my 8.25 axle. $300 or BO.
The skid plate bolts up to the differential anf truss with the two welded on tabs and clamps to the front yoke. The traction bar bolts to the skid plate and then to a crossmember on the body of the Jeep. I tried to fit it on my 8.8 but the traction bar hits my driveshaft. It quite possible could work on axles other than CHry 8.25.
You will need to provide the two tabs for the differential, two on the truss and the crossmember on the body of the jeep.
I have a traction bar and skid plate that used to be on my 8.25 axle. The skid plate bolts up to the differential with the two welded on tabs and clamps to the front yoke. The traction bar bolts to the skid plate and then to a crossmember on the body of the Jeep. I tried to fit it on my 8.8 but the traction bar hits my driveshaft.
You will need to provide the two tabs for the differential and the crossmember on the body of the jeep.
The picture of the axle is just so you can see how it attaches to the differential.
