XJ No start, No Crank
b_palmer22
Military
Hey guys, yesterday out of nowhere my 2000 XJ wouldnt start. There's just a relay that clicks then the dash dies when you hit the ignition and the dash wont come back on for 30 seconds. Battery gets no load. Any ideas? The ignition has been questionable latley. The key has been pulling out. Yesterday before it died completley it was weak starting, The battery was replaced in july and is still good. Any suggestions would be great. Thanks guys!
The only thing that has me thoroughly sketched out is that the ignition wont come back on immediately after i turn the ignition and all the guages are dead. For about 30 seconds.
when I did my headlight harness upgrade a few weeks ago i cleaned, and reseated cables. I may pick up another end and replace that before i go trying to replace the whole starting system.
Clicking and not starting is usually a low voltage issue from:
dirty, corroded, or loose wire connections
internally corroded battery wires
• leaving the lights on
• a failing battery
• a failing alternator
Perform routine maintenance of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables or connectors and replace as needed. Copper wires should be copper color, not black or green. Do the same for the grounding wires from the starter to engine block, the ground wires at the coil, and the ground wires from the battery and engine to the Jeep's frame/body. You must remove, wire brush, and clean until shiny the cable/wire ends and whatever they bolt to.
Jeeps do not tolerate low voltage, bad connections, or poor grounds.
Place your DVOM (Digital Volt Ohm Multi-Meter) on the 20 volt scale. First check battery voltage by placing your multi-meter's positive lead on the battery's positive post ( the actual post, not the clamp ) and the negative lead on the negative post. You need a minimum of 12 volts to continue testing. Next, leave your meter connected and take a reading while the engine is cranking. Record this voltage reading. Now connect your positive lead to the battery terminal stud on the starter and the negative lead to the starter housing. Again, crank the engine and record the voltage reading. If the voltage reading at the starter is not within 1 volt of battery voltage then you have excessive voltage drop in the starter circuit.
Typical voltage drop maximums:
• starter circuit (including starter solenoid) = 0.60 volt
• battery post to battery terminal end = zero volts
• battery main cable (measured end to end) 0.20 volt
• starter solenoid = 0.20 volt
• battery negative post to alternator metal frame = 0.20 volt
• negative main cable to engine block = 0.20 volt
• negative battery post to starter metal frame = 0.30
• battery positive post to alternator b+stud = 0.5 volt with maximum charging load applied (all accessories turned on)
Test the output at the alternator with your volts/ohms multi-meter. You should be measuring 13.8-14.4 volts. Load testing the alternator is still recommended.
Have your helper turn the ignition key to START while you tap on the starter with a hammer. If the engine starts, you probably need a new starter.
Have the battery, starter, and the alternator Load Tested for proper function in a test machine that applies a simulated work load. Handheld testers are inaccurate and will often pass faulty parts.
