Old April 18th, 2007, 18:58
8Mud's Avatar
8Mud 8Mud is offline
Grounds
I'm fairly familiar with the grounds under the hood (Renix), but haven't found many behind the dash. I'm sure they are there, just never had much experience with them.
I jumped the ground to the power window circuit under the drivers side kick panel. And while I was in there jumped another ground wire mounted to the lower left bottom of the dash. Tied them all together and made a new ground to the dash brace bolt.
Headlights got brighter, power windows nearly doubled there speed and if I'm not imagining things my idle smoothed out some.
I've looked through some diagrams trying to figure out what I did and can't find a location for grounds G102, G103 and G 104.
The best solution would be to leave it the heck alone and be happy, but I'm a curious sort.
All the wiring in an XJ harness and the ground circuits, most all flow through splices to maybe a dozen grounds, through anemic wiring. It's almost like the engineers forgot that DC electric is a loop.
Old April 18th, 2007, 19:07
Blaine B.'s Avatar
Blaine B. Blaine B. is offline
Re: Grounds
Yeah, alot of the grounds are pretty lame.
But it's within code and doesn't spark flame, so it's accepted
Old April 18th, 2007, 20:01
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Re: Grounds
I had the same issue with my 87. Practically everything on the vehicle grounded through the cigarette lighter.
Old April 19th, 2007, 07:30
RichP's Avatar
RichP RichP is offline
Re: Grounds
When I first got my 98 I planned on adding various electric things inside so one of the first things I did was run tow 10ga wires from the PDC and battery ground to inside the dash. I attached the ground to that big alulminum brace under the steering wheel mount and since then have run any grounds to stuff I added to that point. It even had a nice empty threaded hole in it too....
Old February 15th, 2009, 09:03
88XJSport's Avatar
88XJSport 88XJSport is offline
Re: Grounds
Apologies for bringing up an old thread...but do you have a picture of this?
Old February 15th, 2009, 09:15
8Mud's Avatar
Re: Grounds
No I sure don't, it was an experiment when I first did it. But the test of time has proved it's usefulness, things still work well.
I do still have one slow window though, so it's likely my approach needs some more work/research.
Basically what I did was to integrate the power seat circuit with the window circuit (behind the drivers side kick panel and the drivers door sill harness). And add some grounds to chassis, for the ground wires for both circuits, behind the drivers side kick panel.
In affect doubling (most of) the available amperage to one or the other circuit, unless you try to work both at once.
If your still interested, after it warms up some, I'll take some pictures and draw some diagrams.
Old February 15th, 2009, 09:21
88XJSport's Avatar
Re: Grounds
Pics and diagrams will be nice. I need things spelled out in diagrams and pictures, because I understand it better that way. Wait till it warms up though, and I appreciate your help.
Old February 15th, 2009, 09:22
wim hoppenbrouwers's Avatar
wim hoppenbrouwers wim hoppenbrouwers is offline
Re: Grounds
Hallo Jeepers and 8Mud. I post already these pics, but maybe still useful. It's 2000 model. 2 pics. please click.
headlight grounds ChandlerXJ OEM Tech Discussion 4 May 15th, 2005 17:55
Proving Grounds (Moab) ROKTAXI Land Use Forum 3 March 2nd, 2005 21:24
Replacing under the hood grounds.... csr_011 OEM Tech Discussion 8 December 18th, 2004 08:40
Grounds??? Ghost OEM Tech Discussion 9 November 23rd, 2003 16:49
