Old August 23rd, 2008, 18:36
GrimmJeeper's Avatar
GrimmJeeper GrimmJeeper is offline
0331 head swap question
swapping a 97 0331 head onto an 01 block, and the 97 head is missing the bolt hole for the idler pulley. any ideas? help! all work has come to a standstill!
Old August 23rd, 2008, 18:41
johnnyc's Avatar
johnnyc johnnyc is offline
Re: 0331 head swap question
You sure about that Mike? A 97 should have the 0630 head.
Old August 23rd, 2008, 18:42
well, the bill says 97 head... help johhny we are at brendan's and stuck!
edit...'doh! the head says 0630.... but its still missing the idler pulley hole i got it backwards... we are REPLACING a 0331 head with an 0630
Old August 23rd, 2008, 18:45
johnnyc's Avatar
Check the casting number on the head. If it's an 0630, then it may not have that hole to mount the 01 idler pulley.
In which case
Old August 23rd, 2008, 18:48
BIGSLVRXJ BIGSLVRXJ is offline
What idler pulley are you referring to? The 96+ serpentine belt idler pulley bolts to the water pump with 2 bolts and into the block with 1 bolt, the head doesn't factor in at all. You're not by chance talking about the coil pack rail are you? That is the one modification I know of when putting a 0630 head where a 0331 used to be.
that's exactly the problem. what now?
Old August 23rd, 2008, 18:49
we are putting a 97 0630 head onto a 01 block that had a 0331 head on it. we need to figure out how to mount the idler. i screwed up in my original post. too many beers its a good thing im not the one turning the wrenches, haha.
Old August 23rd, 2008, 18:54
Set the Nasty Ice down and type Grimm . I'm still confused at where you're stuck...can you elaborate more? The idler pulley mounts to the power steering pump bracket below the pump itself. That power steering pump/idler pulley bracket mounts to the block and the water pump, but nowhere in there to the head.
Old August 23rd, 2008, 18:59
0331:
0630:
Old August 23rd, 2008, 19:00
Is that a WJ or TJ block in the first picture, on an '01 XJ there is no idler there...I'm very confused and intrigued now. Can you just bypass the idler? And, are you flipping me off in the 2nd picture ?
Old August 23rd, 2008, 19:07
WJ, and not so much you, but the whole situation.
Old August 23rd, 2008, 19:24
game over? nobody ever put an 0630 head on a wj block?
Old August 23rd, 2008, 20:23
Sorry Grimm, other than actually bypassing it somehow you've reached the end of my ideas. Could you put a 96+ XJ serpentine setup on it and eliminate the idler there altogether? Similar to this...
I know up until '95 ZJs used the same tensioning system as XJs although after that, the two differed slightly. I wouldn't be surprised if you could just an XJ ps pump bracket and use the rest of the WJ stuff to make it work. Like I said, that'd be the end of my ideas...
Old August 23rd, 2008, 20:56
thanks but on the newer models the ac pump is under the ps pump, and the alternator is where the ac pump used to be, and on the WJ the belt runs ps pump -> idler -> alternator i am out of ideas. we closed it up for the night.
thanks for the replies tho
Old August 23rd, 2008, 22:33
Fergie's Avatar
Fergie Fergie is offline
Me think I'll hit the machine shop with both heads on monday, and have them drill a hole in the proper location, and call it good.
0331 head swap, mpg change? indy_xj OEM Tech Discussion 24 February 17th, 2008 21:57
Would you buy a 2000 with the 0331 head? rocknxj Sierra Chapter 7 February 11th, 2008 06:27
valve carbon or 0331 head issue? 0630 swap? wilsmick OEM Tech Discussion 12 May 22nd, 2007 21:13
0331 head [low emission] Dmanti OEM Tech Discussion 4 January 9th, 2007 18:48
0331 head Identifing dyna OEM Tech Discussion 6 July 28th, 2006 18:47
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
