Old July 1st, 2022, 11:27
Black_Black Black_Black is offline
Help please, fuel pump not priming
I did all my seals, cleaned oil pump, no fuel pressure. Been cranking with no spark. Started for a few seconds and it sounds BAD. What should I do?
Old July 1st, 2022, 12:18
Anak's Avatar
Anak Anak is offline
Stranger
Re: Help please, fuel pump not priming
You have no spark and no fuel pressure, but it cranks?
When you say you did all your seals, what exactly do you mean? Did you replace the fuel tank sending unit O-ring? That would mean you had the pump out. Perhaps you damaged the wiring/broke a connector/broke an old, brittle fuel line.
Did you remove the distributor to replace the seal under it?
Some clarification of what you have done might help so folks can better advise you.
Old July 1st, 2022, 13:06
I got fuel pressure turning the pump with a screwdriver, thanks!! I was doing the renix distributor indexing now it seems my timing is 45 degrees off? I can't get it anywhere close to the rotor what's going on?
Old July 1st, 2022, 13:12
Sorry to double post. Things could only be 180 degrees off right? The harmonic balancer only goes on one way.. Been playing with it for a while
Old July 1st, 2022, 19:51
Anak's Avatar
Stranger
You got fuel pressure turning the pump with a screwdriver?
Old July 2nd, 2022, 08:52
lawsoncl lawsoncl is offline
Reference http://cruiser54.com/?p=68 for the indexing. Make sure you got the wires back in the right spot. Some of the diagrams out there (Chiltons) have the wires rotated and in the wrong spot.
Yup, harmonic balancer is keyed and only goes on one way. Won't affect timing even if you could.
Did you mean you got oil pressure spinning the distributor? You could be 180* off on the distributor too.
Old July 2nd, 2022, 14:41
I had to line up the oil pump again, got distributor indexed everything seems fine. Thanks for the help
Fuel Pump Not Priming tylergrant2011 OEM Tech Discussion 11 February 12th, 2017 17:32
Renix Not starting. Fuel pump not priming. only 7v at pump. tayman OEM Tech Discussion 203 September 14th, 2012 05:21
Renix Not starting. Fuel pump not priming. only 7v at pump. tayman OEM Tech Discussion 0 August 14th, 2012 13:19
Crank, no start; fuel pump not priming? kujito OEM Tech Discussion 29 July 10th, 2010 11:44
Fuel Pump Priming ? /Starting jeepsrock OEM Tech Discussion 5 June 15th, 2005 01:49
