Old January 6th, 2019, 22:09
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: Gratuitous Lack Of Moderation - A little stroker build
It's so pretty.
But we're going to talk about it at a later date. The cam for this motor is not back from being nitrided and Russ happens to be out of valve guide seals for the Edelbrock head, which are not the same as the standard 4.0.
So that's as far as we got. For those of you keeping score, that was ~11-13 hours of build time (2 days), and we started with all machined parts. Russ is super meticulous about assembly, which is why his lead time is so long.
But if you happen to be waiting for a motor, it's probably right here, in a mountain of machined blocks awaiting assembly.
And here's a retirement funds worth of cylinder heads. All ported and polished, and waiting for you to buy them.
Old January 7th, 2019, 05:32
Redsnake Redsnake is offline
GREAT thread so far!! Awesome to follow-along w/this one.
Old January 7th, 2019, 06:10
XJwonders XJwonders is offline
Huh, what?
Yep. Great thread to follow.
Old January 7th, 2019, 12:52
denverd1's Avatar
denverd1 denverd1 is offline
sweet. What displacement?
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old January 7th, 2019, 16:38
techno1154's Avatar
techno1154 techno1154 is offline
Something interesting I see here. I know there is a good reason for doing it but I just so not know the reason.
There is a diagonal grove across the camshaft bearings, Why is that?
I have rebuilt dozens of engines as a marine mechanic,... Fords, Chryslers and mostly GM's and I never seen that.
It is good to see Russ is almost as meticulous as I used to be when rebuilding an automotive 350 block to change it from 260 +/- HP to 500 + hp to do amateur boat race.
Post up some dyno numbers. Reading this sends shivers down my spine with anticipation and excitement. Beautiful job!!
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old January 7th, 2019, 17:39
GreaseMonkey17 GreaseMonkey17 is offline
Makes me want to build a stroker for sure awesome pictures and info !
Old January 7th, 2019, 18:33
cal's Avatar
cal cal is offline
You may not know this about Russ but 1500+ horsepower Chevy is his bread and butter. Strokers were a hobby that has become profit after the LS changed the hot rod scene.
As far as that bearing goes, it's just that one, and all 4.0's are apparently that way. Dunno why, but I asked about it too.
Old January 7th, 2019, 18:34
cal's Avatar
cal cal is offline
Loosley 4.7, 11.35:1 compression.
If you want exact numbers you need to wait until we're done measuring.
Old January 7th, 2019, 22:24
twinhauler's Avatar
twinhauler twinhauler is offline
keep it coming. Should be a great engine!
Old January 8th, 2019, 06:16
techno1154's Avatar
That is what makes him a pro. I am just a novice who have a few dozen rebuilds mostly to original specs. Looking at a pro doing meticulous work remind me of my past.
Patrick
#594
Old January 8th, 2019, 07:42
RedNeckRea RedNeckRea is offline
post for following.
Old January 8th, 2019, 08:48
denverd1's Avatar
close enough for me. got a target HP in mind?
Chili Pepper '98
Old January 8th, 2019, 10:45
StinkyFab's Avatar
StinkyFab StinkyFab is offline
NAXJA Supporting Vendor
Enough to break a D35 doing a burnout on gravel?
Oh wait, you only need like 10hp for that.
Dallas Ashley
WWW.STINKYFAB.COM
Motor Mounts, Fabrication tools, and Custom stuff for your Jeep!
Old January 8th, 2019, 11:34
denverd1's Avatar
lol
Chili Pepper '98
Old January 8th, 2019, 13:24
cal's Avatar
cal cal is offline
all of it.
Stroker build kf_chris Modified Tech Discussion 33 January 4th, 2010 20:21
99 xj stroker build WHITE93 Modified Tech Discussion 1 May 2nd, 2009 11:25
4.6L Stroker, Help me build it please! XJoshua Jeep Street and Performance 277 February 28th, 2009 00:18
Stroker Build missionstroker Jeep Street and Performance 15 December 12th, 2007 07:08
Want to build a Stroker? robert stalberger For Sale: Private Party Only. XJ ITEMS ONLY 1 September 12th, 2006 14:08
