Old September 24th, 2015, 16:08
Dragonlich1961 Dragonlich1961 is offline
Looking for suggestions on a new rear axle. (noobish)
I've got a 94 2 door auto 231 combo with abs(hence my problem).
I've got 3 inches of lift. rough country a.a.l with new coils.
I'm looking to upgrade my rear axle to something better. my future plans are 4.5 inches of lift ish and 32-33's. i know the dana 35 isn't great. what would be the best axle for me. i know a 8.8 and 44 are decent, but would a 29s 8.25 work fine?
Is it worth my while for a 29 spline 8.25?
I don't plan to ever go over 4.5 or excessive trimming. i like the improved factory look and it's to high for my liking and she is my daily right now.
also can a 29s 8.25 be found with a factory ls? my tudry-5 has a one right now(factory). i know the after market has one. my mother has a 02 kj with a ls we put in when it's axle took a shit.
Thank you guys for help.
(if this is in the wrong spot please let me know. I'm new here and it's my first post.)
Old September 24th, 2015, 16:14
thanasi85's Avatar
thanasi85 thanasi85 is offline
Re: Looking for suggestions on a new rear axle. (noobish)
Chrysler 8.25 29 spline axle is a great axle that isn't to expensive or hard to find. I upgraded to one under my rig and so did my brother, we are both running 35's with stock gears, his is locked and mine has a LSD, both are trussed and I don't get out wheeling as much but my bro wheels the crap out of his rig doing the Rubicon a few times a year and other trails and neither of us have broken shafts or had any issues.
Old September 24th, 2015, 16:16
thanasi85's Avatar
My 8.25 with limited slip came out of a 99 2wd XJ. Not sure if they came with LS in any of the 4wd XJ's
Old September 24th, 2015, 16:59
Ah thank you good sir. Im new to naxja and xj's, it's my first car for while i'm at college. I'm not a rockcrawler type of guy, i'm more of a forest trail type so i don't think i need pure beef but a least something better. plus discs would be nice.
Old September 24th, 2015, 18:21
Royal Nonesuch Royal Nonesuch is offline
8.25s don't come with discs, but you could do a ZJ disc swap while you're at it. 29spline 8.25s w/LSD go for about $200-250 near me (Southern Cali). I got my non-LSD axle from a low-milage 2001 for $125.
It's a good axle, I put one in mine to replace the 35. I only run 31s but I enjoy wheelspin and not worrying about it when I'm out in the boonies. Perfect for your college DD + forest service roads. It was an easy swap, my friend and I swapped it in an evening with no prior experience in that sort of thing.
Old September 24th, 2015, 18:47
thanks. this is my second xj technically but my first car.
my first one i had was totaled after only a month of owning it. hit and run by a full size truck crushed my passenger a pillar 6 inches. another two door 4.0 auto with the lift now on my current rig. it had an 8.25 but 27s. junked the axle with the striped body since my father was insistent on keeping abs at the time.
ive thought about doing the disc swap for better brakes. yes indeed the factory one sucks. nice think about the 8.25 is it's a bolt in swap if left drum. the discs could be installed off the car for an easier install.
Old September 25th, 2015, 20:29
88trailcrawler's Avatar
88trailcrawler 88trailcrawler is offline
MJ 44 under mine, but I think the MJ/XJ 44's are getting hard to find.
Old September 26th, 2015, 01:03
Hypoid's Avatar
Hypoid Hypoid is offline
Sounds like you are ready to do away with the ABS, which is what happens when you get away from the D-35.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old September 26th, 2015, 01:09
Demonoid369's Avatar
Demonoid369 Demonoid369 is offline
LSD 8.25 came In the upcountry packaged xj's so look for that, also look in the glove compartment for the las sticker if you're at the junk yard to see if the vehicle came with it.
Old September 26th, 2015, 08:14
Yeah. i know the abs system is pathetic and the drums with it just don't stop worth a damn.
I looked into the d44 but the rarity of them means a higher cost. I want to do this right but my other project back home takes priority. 1961 ford ranchero that funny enough is getting a ford 8.8 under the rear. yes it's the explorer axle
Would it be possible to find a lsd 8.25 with 4.11? i know i can add it later but if i upgrade to the new axle, why not get the lsd to.
would it be worth while to wait for the right axle to enter the yards or jump on one if i could at least fine a 29 spline with 4.11. if i upgrade to an open, i loose lsd( apparently my d35 came with a factory true-track)
Old September 26th, 2015, 09:12
PhotographerMike's Avatar
PhotographerMike PhotographerMike is offline
Many '96 and later 4 cyl. Manual trans. Cherokees came with 8.25 and 4.11's.
BUT, they can be either 27 or 29 spline and you can't be absolutely sure without pulling an axle and counting.
First mod. I did to my '96 2wd. was add a PowerTrax Limited Slip locker because it's embarrassing getting stuck on wet grass . . .
I've had it in for 50K+ miles and been through Death Valley, Joshua Tree and many other "four wheel drive" roads (except for that time on Cleighorn . . . )
Mike
Old September 26th, 2015, 10:12
neanderpaul67's Avatar
neanderpaul67 neanderpaul67 is offline
I used a Ford 8.8 from an Exploder ( Explorer��) came w/ a posi and I haven't broke it yet..... But I was able to put it in because I have fab skills... If U know a welder or can do it yerself it's a nice way to get posi & disc brake rear w/o too much hassle
Old September 26th, 2015, 10:42
RedHeep's Avatar
RedHeep RedHeep is offline
NAXJA #1499
My first rear axle swap was an 8.8 and it's a cheap option for strength and disc brakes. But it's also an anchor.
For someone who's sticking to 33's or 35's, an 8.25 comes ready to bolt in and is some junkyard parts away from disc brakes. It doesn't hang the diff low like an 8.8 is.
Old September 27th, 2015, 11:17
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
C8.25 29-spline should be plentiful. Gear ratio will vary, of course. If you still with 97-up XJ then it will be 29-spl. and as already stated 4cyl + manual will most likely have 4.10s.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Axle pin won't align with axle... suggestions? yzmuddereffer Modified Tech Discussion 7 September 2nd, 2013 09:10
kinda noobish driving impression question... jeepdreamer Jeep Street and Performance 4 June 17th, 2012 06:42
Noobish Mod related type question NickDanger_XJ NorthWest Chapter 27 April 25th, 2010 10:40
Open rear axle..Suggestions?? RWD Modified Tech Discussion 10 September 21st, 2006 20:41
do i have a locker in the front? (extremly noobish) jeepster OEM Tech Discussion 3 December 25th, 2003 20:49
