Old December 11th, 2013, 14:52
Smittymark1 Smittymark1 is offline
Axle swap on 94 xj suggestions tips pointers
I recently purchased a 94 cherokee and the rear rend needs to be replaced.... I have done quite a bit of research and landed on the ford nine inch and I was told by a guy to just go measure ones width and go from there his case he got one out of a 74 galaxy I think and put it in his dodge single cab...what years and or models would be best to pull a rear end out of and make it easier , cost efficient or line up the best for the 94 xj don't butcher me too bad it's a project I just picked up wanting to put 35s tops trying to dd and play in it too Any help will be appreciated thanks.
Old December 11th, 2013, 15:32
JWheeler JWheeler is offline
I'm not sure what us required to swap in a 9in but if you are looking for kinda easy and low cost, I just swapped in a Dana 44 our of another xj and it bolted right up. May be something to look at if you are not set on the 9in and want something easy.
Wiggleworm Wiggleworm is offline
Re: Axle swap on 94 xj suggestions tips pointers
Popular swaps are Ford 8.8 from a 95-01 explorer. Gives you discs and is stronger than a 35. Requires some fabrication and welding. An 8.25 from another cherokee is almost a bolt in. May have to change driveshaft, not sure. Or a 44 from an older cherokee. Almost a bolt in. May have to change driveshaft. Do some searching and reading. Lots of people on here have swapped rear ends.
Old December 12th, 2013, 19:12
Thank you I think I'm leaning towards the 8.8 for ground clearance as I'm not going to run much more than 35s what else is actually needed on the 8.8 out of the explorer to put do I just get the ruff stuff axle kit and could the stock shaft out of the explorer work
Old December 12th, 2013, 19:21
xtimmax xtimmax is offline
You'll also probably need to regear an axle to have match gear sets so you can still use your 4wd
Old December 13th, 2013, 06:33
Mnkyboy Mnkyboy is offline
Why not just get a 29 spline 8.25 from a later XJ? Its a bolt in and will hold 35s just fine.
Old December 13th, 2013, 07:40
1x1_Speed_Craig 1x1_Speed_Craig is offline
We installed my old 2005 LJ (Unlimited) axle in my daughter's '97 XJ 2-door. We trussed/re-bracketed the LJ Dana 44, which already had 3.73 gears with Trac-Lok, disc brakes, etc. Yes, it required work, but it was the perfect width, bolt pattern, and it only had 53K miles on it.
So, consider a TJ/LJ Dana 44 while you're looking at options.
Installed in Mira's XJ
Here's Mira removing the factory coil buckets from the axle (from a Jp Magazine excerpt)...SO PROUD!
Old December 13th, 2013, 09:23
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
For pretty much plug n pray, I would go with a 29-spline 8.25 or an XJ D44. Easier to find matching gears, or if you get a pair of axles from a 4 cyl XJ they will most likely have 4.10. If you find a super rare 4 cyl auto, should have 4.56's.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Engine & Trani swap tips nh-jeep OEM Tech Discussion 4 February 24th, 2012 21:54
Anyone with Speedi Sleeve on Axle experience, pointers plz!!! xjnuttier OEM Tech Discussion 3 November 19th, 2009 08:23
V8 Swap, Need radiator tips, ideas Mudshovel_009 Advanced Fabrication and Engineering 3 June 6th, 2007 12:06
front axle swap- d30-suggestions? bcmaxx Modified Tech Discussion 8 March 5th, 2007 11:16
AW4 Swap Any Tips? Scrub2k OEM Tech Discussion 5 December 18th, 2005 04:34
