Prev Previous Post   Next Post Next
Old March 15th, 2019, 07:39
CLSegraves CLSegraves is offline
Stiffen Rear Frame?
01 4 door XJ.
I'm looking for a way to stiffen up the rear cargo area/rear hatch area of my XJ.
I was out wheeling last night and stopped on a really flexed spot (I was checking suspension component clearance/etc. after making changes). I opened the rear hatch to get something and then couldn't get the rear hatch to close correctly (it latched fine after I got back on flatter ground).
Now yes, the simple answer is "don't open the rear hatch when the body is flexed out" but I'm taking this "issue" as an indicator that the rear of the body is twisting and that's something I'd like to prevent (less twist = longer lasting body).
I've already done 3/16" welded frame stiffeners from front to back. I'm thinking of welding a piece of 3/16" plate on the back side (fuel tank side) of the rear crossmember (where the bumper bolts onto). If anyone else has some suggestions/experience in stiffening the cargo area, I'd appreciate the insight. I'm trying to avoid a cage as it's also a daily driver and I don't want to loose the versatility.
Stiffen Leafsprings without more lift. xCWolf Modified Tech Discussion 6 September 7th, 2017 11:20
plating rear of frame vs. rear bumper dfarmxj Modified Tech Discussion 13 February 13th, 2013 15:27
To stiffen or not to stiffen?!? jeepxj2007 Modified Tech Discussion 23 February 1st, 2011 19:13
Rear Frame Killer95_XJ Paint and Bodywork forum 5 April 6th, 2009 16:26
rear frame stace Advanced Fabrication and Engineering 4 February 4th, 2007 07:41
