HeavyMetal
- Fairfield, CT
So, noticeable at low speeds, and sometimes mid-speeds, i get a click click click or maybe clunk or knock however you wanna describe it, only on acceleration, not engine related as i can rev in neutral however much i want and can never replicate the noise. the speed of clunks seems to coincide with wheel speed. wheel bearings are brand spankin new. in conjunction with this is a squeek squeek squeek fast paced noise, itll happen on acceleration or when im on the gas or on the brakes slowing down. the squeek seems to be dependent on engine revs While driving, it cannot be replicated revving in neutral or even moving in neutral, the car has to be in drive.
the knock seems to get worse in reverse but im not sure.
also how much play should the rear axle yoke have on my d44? i removed the rear shaft to check it and i have a good 1/4" back and forth of just play(spinning it, not side to side motion) in the yoke on the 44.
