Remote Start - Blower Motors Don't Turn On
GreatOdin'sRaven
Las Vegas, NV
Hello,
1999 Cherokee Limited 4.0
I've installed a remote start on my cherokee. It successfully turns on my jeep but doesn't run the blower motors.
They turn on when I put my key in and rotate forward.
I searched through threads and found this post:
Not a stupid question at all... as it turns out I am the stupid one here. After tracking down a FSM I noticed tat when installing the remote start in a 97+ (?) you need to tie both into the keyed 12 (run circuit) and the black/orange wire (ACC) in order to get the blower motor circuit to work. Everything works like a charm now.
Thanks for the help guys.
I don'tunderstand. black/orange is Ignition 2 for my cherokee
Does this mean split the wire from the remote start unit labeled "(+)12V Output to Accessory" to both Black/white (accessory) and Black/Orange (Ignition 2) ??
Anyone run into this problem before?
If they aren't fed power thru the remote start circuitry you added, they won't turn on.
I added a remote start to a car I had once, and I fed power from the remote start system to the blower fan, but forgot to feed power to the A/C circuit, so their was no power to engage the clutch on the compressor, so I had no A/C cooling when using it. Heat worked fine (which is what I really wanted anyway), but you don't need to engage the compressor clutch for heat.
Find the power lead to the blower and tie it in.
