BIG1RED9
- Coarsegold CA
Today I briefly got stuck. Turned the key, heard the fuel pump - no crank. Giggled connectors and relays - nothing. Tapped the starter and it cranked at a lower RPM then typical but it started. Got it home charged the battery, same lower RPM cranking starter issue.
OEM part number shows a 4 post Battery, Solenoid, Ignition and Ground.
Digging around the forum a 5 post is discussed which adds a fuel pump.
Current relay is a 4 post, however there is a light green wire with a female flat connector which is not connected to anything floating nearby
To beat the time cut off I ordered a new AC Delco starter and a 4 post starter relay Standard Products (SR-105). Is the 4 correct? What is the light green wire for?
Appreciate the help!
