Baddad
- Seattle, wa
1990 Limited, factory abs which I converted to non abs. (Dual diaphragm booster/master cyl) So, when I pull the park brake, no light on the dash. Turn the key to run position, no dash brake light. Crank the engine and the light comes on while cranking, turns off as soon as it starts. So the bulb is working. Checked the park brake switch and it’s functioning as intended (goes to ground with the lever pulled). All fuses check out. All the abs components have been removed, however the wiring is still there, just unplugged. Is there a wire or something in the abs harness that needs to be connected or grounded to make my park brake indicator work properly? I have an explorer 8.8 and every time I get the park brake working right, I drive with it engaged and then it throws off all my adjustments! Very frustrating
