Old June 20th, 2018, 16:20
98XJTyler 98XJTyler is offline
steering stabilizer questions
I am in need of a steering stabilzer for my xj and noticed a crazy price difference in the price of fox stabilizers for the xj and the jk. I wanted to know if that price difference is due to the stabilizer being built solely for stock xj steering. I have a cavfab steering kit so i was curious if i could just get the fox jk stabilizer and use that. Thanks in advance.
Old June 20th, 2018, 17:24
RCP Phx RCP Phx is offline
Re: steering stabilizer questions
Well do what you want since a steering damper is not needed anyway!
Old June 20th, 2018, 17:29
sinat01's Avatar
sinat01 sinat01 is offline
order one from doetsch tech, they have their normal twin tube is like $40 but they do make a monotube stabilizer that's $121. their high end stuff is waaay better than fox or bilstein
Old June 22nd, 2018, 12:33
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
Not true.
A more correct statement would be, that a steering stabilizer should not be used as a band-aid to cover up worn or improperly designed steering components.
My WJ OTK setup is dialed in and performs flawlessly on the road and off, but a stabilizer is a nice addition to soften the jolt transmitted to the steering wheel when traveling off-road on rubble strewn, rutted or washboard tracks for long distances.
The FOX ATS and Teraflex Falcon units are definitely high end and spendy, but the ability to tune them is nice and the pass-thru design eliminates the mild steering pull that is typically associated with a gas charged unit. I scored a smokin deal on a low-mile Fox ATS unit a few weeks ago that had been run on a JK, before the owner move up to 1-tons, 40's and hydro assist.
Speak the Truth-Question with Boldness-Speak without fear.
Old June 22nd, 2018, 13:37
cwyman6 cwyman6 is offline
Originally Posted by XJEEPER View Post
Not true.
Exactly. Rubicon express also makes a pass thru. I run ome
Old June 22nd, 2018, 14:25
Wiser's Avatar
Wiser Wiser is offline
Not sure on the differences in prices. Sorry if that doesn’t help but I’m running the Cavfab steering also but without a steering stabilizer. Stabilizers are not needed providing everything is dialed in on the front of your Jeep.
2018 Jeep Cherokee KL
1 ton Tube Buggy
98 XJ 2Door “The Mule”
Steering Stabilizer One Cylinder Add-On for Double Steering XJ-ZJ-TJ ONDAROX NAC Classifieds 2 June 6th, 2011 18:45
Steering Stabilizer/ and Shocks Upgrade Questions??? btm757 Modified Tech Discussion 7 November 17th, 2009 20:30
steering interfering with Steering stabilizer shock Throttle Modified Tech Discussion 24 April 13th, 2008 09:39
Mounting a Steering Stabilizer with 1" OTK Steering? barillms Modified Tech Discussion 7 April 6th, 2008 20:20
steering stabilizer with crossover steering, needed or not? Jeepin Jason Modified Tech Discussion 13 February 2nd, 2007 19:22
