Old May 23rd, 2017, 10:31
92xjRJ 92xjRJ is offline
Re: 93 XJ BUILD (WITH LS SWAP)
Originally Posted by cleenrob View Post
i dont remember for sure what the cut off is but i think 06 4l60es are contolled a bit different than -05
Yeah I dug a little deeper and the 06+ have the input speed sensor. Gonna have my ecu flashed to an 04 to resolve this.
Old May 29th, 2017, 15:19
So got to do a little today, I took the jeep harness out and while pulling out interior pieces I pulled up the carpet and found this....
Old May 29th, 2017, 20:16
clydefrog's Avatar
clydefrog clydefrog is offline
You have the built in water drainage mod! It is an XJ specialty.
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old May 30th, 2017, 19:32
Just add it to the list of steel I need to reenforece this thing anyways haha
Old May 30th, 2017, 20:47
Jeep Driver Jeep Driver is offline
That is perfect for a fiberglass repair.
Four layers of glass and it will be stronger than it ever was.
Old May 31st, 2017, 10:37
PhotoJared's Avatar
PhotoJared PhotoJared is offline
I'm so glad to have a Southern California/Nevada car....
Old May 31st, 2017, 15:20
i feel you there, i was not expecting it to be honest. The jeep is really clean...well i thought it was haha, mine may be in california now but when i bought it for a whopping 500 bucks she was a utah plated vehicle so that explains that.
Old May 31st, 2017, 15:21
eh, my dad does sheet metal work for a living ill probably just end up having him help me out with that.
Old March 6th, 2018, 11:47
been a while since i have been on here or updated, alot of stuff came up and the build got put on hold, im just now jumping back into, my motor will be done here soon added some stuff, i ended up with a texas speed and performance cam, hardened pushrods and springs for more lift. When i tore into my motor i found the piston skirts slightly scrapped and the front cam bearing was gouged. I will have the block back soon with new bearings. The heads were cleaned up decked and had a little porting done. While the motor is out, im trying to handle some of the wiring. On the jeep side of things what all do i need to keep? Ignition, battery, and interior stuff?
Old March 8th, 2018, 15:23
those of you that have done this swap before, is it possible to use a NP241c from a late 90s gm? For easy of going together with the 4l60e.
Old March 9th, 2018, 00:02
indian's Avatar
indian indian is offline
241c should be bolt on
I used 231J with adapter
Old March 9th, 2018, 16:22
cleenrob's Avatar
cleenrob cleenrob is offline
yes, you can get an sye for it from jb conversions
also they had a couple different spline count input shafts
you want the 27 spline
Old March 14th, 2018, 09:34
Thanks guys! I kind of figured it would be. You don't think there would be any tunnel or clocking issues?
Old November 2nd, 2018, 11:03
So since I haven't posted in a while, not much has changed, got my lady Into a newer dd so it put me on pause for a while. It's pretty cool though (4runner). But as far as the swap I'm just waiting on the accessory drive brackets and I'll drop it in and start saving for a trans. Also I purchased the harness from PSI conversions and i must say I'm very satisfied with it! Great quality!
Old November 16th, 2018, 10:38
Been on a bit of a budget lately but I have been sourcing small little pieces to get this thing rollin. I just picked up a cooling fan from a 99 Volvo s70 I believe, pretty much the same as the Taurus fan but it comes with the relay block and easy wiring! Also have most the parts to do my fuel system, areomotive adjustable fuel pressure regulator and new -6an fuel line with pushlok fittings, removed abs hardware and got an adjustable brake proportioning block since I will be going to the 8.8 with disk in the rear it will be easy to adjust on the fly.
93 XJ BUILD (WITH LS SWAP) 92xjRJ Modified Tech Discussion 0 May 5th, 2017 11:21
88 MJ Build / Axle Swap with Q's laxbro37 Jeep Comanche MJ (1985 - 1992) 3 January 31st, 2017 06:35
XJ 5.3 swap (build) blistovmhz Modified Tech Discussion 4 March 19th, 2016 18:26
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 20:26
Santa's tear-down/swap/build-up juryrigjalopy SoCal Chapter 80 August 10th, 2007 15:35
